Blinker Problem - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 17th, 10, 10:22 PM Thread Starter
Adam
Blinker Problem
I am having trouble with my blinker and hoping someone can help. When I turn the blinker to the left, the rear and front lights start blinking perfectly. when i push in the hazards, all four blink great as well. but when i move the blinker to the right, the lights go brighter as they should, but they dont "blink" they just stay bright. Is there any reason it would be doing this? Thanks for any help you guys can give, I searched trying to find my same problem so hopefully this hasnt been answered a billion times.
mowea01 is offline
post #2 of 5 (permalink) Old Feb 18th, 10, 03:35 AM
Brad
RS3SDL2MG's Avatar
Re: Blinker Problem
one of your park/signal lights is not getting a good ground , try just taking a piece of wire and grounding the tailight and front park light housings while the key is on and you have the signal lever on so they should blink , if the start blinking when you give them a ground then that's the trouble ,
another thing it could be and have seen it before is corrosion in the park/signal light bulb socket's take the bulb's out and clean the socket's and put some grease on them then atreinstall the bulbs again with the light on to blink and see if that helps
1967 RS 327
RS3SDL2MG is offline
post #3 of 5 (permalink) Old Feb 18th, 10, 05:38 AM
Christropher
Re: Blinker Problem
Did you check the blinker fluid level?
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 5 (permalink) Old Feb 18th, 10, 12:38 PM Thread Starter
Adam
Re: Blinker Problem
wait..blinker fluid? i didnt think they started coming out with fluid for them until the 4th gen camaros? i guess im confused... i will just have to keep messing with it, but im also a noob and am trying to figure out if im missing where a ground wire would be or something.
mowea01 is offline
post #5 of 5 (permalink) Old Feb 18th, 10, 05:01 PM
Re: Blinker Problem
Try a heavy duty flasher, 552, for the turn signals located in the clip next to the steering column or maybe hanging loose by its harness next to the column.
Keep fiddling with the ground issues mentioned and make sure the bulbs on the right side match the bulb number on the left side, 1157.
