Alternator conversion - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 25th, 10, 03:10 PM Thread Starter
i am converting to the cs alternator and getting rid of the voltage regulator. the alternator i got is a 105 amp (from a 1993 camaro) and the wire lead that i got has a red, black, and brown wire. from what i have found the brown wire connects to the blue wire coming from the voltage regulator and the black wire isn't used. now my question is where does the red wire go to? i have seen places where they say it should go to the battery terminal on the alternator and then others say that it should go to the distribution block. does anyone know where it should be going to??
thanks
dhans21 is offline
post #2 of 11 (permalink) Old Feb 25th, 10, 05:05 PM
Re: alternator conversion
Big heavy gauge red wire goes to the BAT terminal on the alt.
post #3 of 11 (permalink) Old Feb 25th, 10, 05:42 PM
here you go....
https://www.camaros.net/techref/ftecref14.html
http://www.madelectrical.com/electri...elcoremy.shtml
68 Camaro~LSx ~all motor
post #4 of 11 (permalink) Old Feb 25th, 10, 07:37 PM Thread Starter
in both of those the alternator just has the 2 spades, but on my alternator i have 4 prongs in which only 3 of them have wires coming out of the plug. thats why i wasnt sure how you went about doing it when you have more than the 2 spades.
dhans21 is offline
post #5 of 11 (permalink) Old Feb 25th, 10, 07:38 PM Thread Starter
what is the purpose of the red wire?
dhans21 is offline
post #6 of 11 (permalink) Old Feb 25th, 10, 07:58 PM
The big red wire is how the alternator supplies power to the electrical system.
dnult is offline
post #7 of 11 (permalink) Old Feb 25th, 10, 08:15 PM Thread Starter
Isn't the wire coming from the junction block the one that's supplying power to the electrical system? Why is it that you need to hook the red wire at the alternator to the battery terminal also?
dhans21 is offline
post #8 of 11 (permalink) Old Feb 26th, 10, 03:13 AM
So the battery gets recharged.
Battery is not an infinite power supply, it needs replenishment just like you need food to maintain power.
Battery supplies stored power when alternator is not running. Once alt is running, it has to recharge battery of more than 20% battery voltage to recharge battery for next time the battery is used. Likewise, the cabling should be of large wire gauge to handle the current demand of both the electrical system and battery recharge.
post #9 of 11 (permalink) Old Feb 26th, 10, 05:20 AM
thanks
The big red wire coming out from the plug is the sense wire for the alt, ( it will sense the voltage for charging level where ever it is connected, some connect it to the charge post of the alt but it realy should be sensing voltage at the point where the electrical system is using power from which is usualy the horn relay on a first gen with std. wire layout.
Riley is offline
post #10 of 11 (permalink) Old Feb 26th, 10, 06:30 AM Thread Starter
Thanks, that's exactly what I wanted to know!
dhans21 is offline
post #11 of 11 (permalink) Old Feb 26th, 10, 01:39 PM
Re: Alternator conversion
This is the directions I got with mine from the local auto parts store....
http://i10.photobucket.com/albums/a1...maro/CS130.jpg
