Gauge Lights too Dim - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 27th, 10, 04:29 PM Thread Starter
Walt
Has anyone on this forum trouble shooted this type of problem The light switch is new for my RS/SS evrything wired up. Turn on the lights and no matter how far you turn the knob it doesn't get any brighter. It only starts causing my gas gauge to go down. I have looked to see if it is getting grounded somewhere but could use some guidance, thanks in advance
69ss/rs69 is offline
post #2 of 4 (permalink) Old Feb 28th, 10, 07:26 AM
madmax87's Avatar
Re: Gauge Lights too Dim
Did you re-install the metal bracket that grounds your headlight and wiper switches? Did you attach the ground strap from the bracket to a good ground on the dash.
I've also had bad aftermarket switches.
The part I'm talking about is in Classic Ind catalog p/n 3937657.
madmax87 is offline
post #3 of 4 (permalink) Old Feb 28th, 10, 08:04 AM
click's Avatar
Grounds are 99% chance of where your problem is. You can't have enough of them.
click is offline
post #4 of 4 (permalink) Old Feb 28th, 10, 09:25 AM Thread Starter
Walt
thanks for the advice, I'll look today since the suns out
