Light switch - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 2nd, 10, 05:51 PM Thread Starter
Light switch
i get small shock when i turn on my lights on my 67 everything new engine, harness etc when i turn then on the gages also peg any suggestions
airbrn7 is offline
post #2 of 4 (permalink) Old Mar 2nd, 10, 09:19 PM
Sean
Re: Light switch
Bad ground almost for sure. Double check the switch is gounded well to the dash and the ground strap attached to the instrument cluster that grounds under the upper center screw for the gauge cluster is intact and making bare metal contact. If the dash has been recently painted or is rusty that would be my guess. Pretty common 67-68 issue.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #3 of 4 (permalink) Old Mar 3rd, 10, 03:37 AM
Re: Light switch
Spray the carpet and seats with anti-static spray if Sean's suggestions don't work.
post #4 of 4 (permalink) Old Mar 3rd, 10, 05:23 PM
Greg
Re: Light switch
Take a jumper wire, touch your door sill plate to the metal dash, lights knob, etc to see if your gauges settle down.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
