Switched 12V source for external fuel pump - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 9th, 10, 07:30 PM Thread Starter
I am looking for recommendations for where to wire in for an inline external fuel pump for going FI on my 69 Camaro. Any suggestions would be appreciated.
69 SS396 Camaro, 4link, 12bolt posi, Speedtech LCA / UCA's, Hotchkis 2" drop front springs/sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
g356gear is offline
post #2 of 6 (permalink) Old Mar 9th, 10, 07:42 PM
Steiner
Re: Switched 12V source for external fuel pump
Use a relay. Supply the coil with a line from the IGN terminal on your fuse block and supply the contacts with a line from the + post on your battery.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old Mar 10th, 10, 03:19 AM
As Steiner suggests, use a relay. I suggest you use a 3rd Gen fuel relay and fuse accordingly, the supply line from the battery or power junction block.
Your decision, but you might use an oil light sending unit in the relay coil circuit to open up when oil pressure drops.
post #4 of 6 (permalink) Old Mar 10th, 10, 03:26 AM
BILL
SPARKY69's Avatar
killer idea, im changing my set up ..
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 6 (permalink) Old Mar 10th, 10, 01:26 PM
I would also look into a hidden switch for the relay so if you leave your car somewhere (out front of a friends house or something) you can turn the switch off so IF someone was to TRY to steal.... they'd get nowhere if they were to hot-wire
68 Camaro~LSx ~all motor
post #6 of 6 (permalink) Old Mar 10th, 10, 02:37 PM
Your ECU should have a fuel pump control circuit built in??
john68 is offline
