Another electrical issue - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 10th, 10, 11:33 AM Thread Starter
josh
ok so last time I posted I had brake light issues along with headlight issues. the headlights was the headlight dimmer connector which is fixed for now the brakes was the brakelight switch which i replaced and worked fine for about two days. Now the brake lights wont turn on but its the weirdest thing the front hazard lights stay on when the brakes are depressed and go off when not depressed. so essentialy my hazard (turn signal) lights are working as the brake lights should. everything has electricity the sockets the brake light switch the bulbs are new and i jus cant figure it out is there a relay or a wire that would be bad to cause the hazards to act like the brake lights. also in the dash the turn signal light illuminates and goes out just as the brake lights should.
any help please it seems like this is just something simple that is bad but i cant figure it out even with the assmebly manual.thanks
josuer302 is offline
post #2 of 6 (permalink) Old Mar 10th, 10, 11:34 AM
BILL
SPARKY69's Avatar
Re: another electrical issue
did you try a new turn signal flasher?
what year car do you have?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 6 (permalink) Old Mar 10th, 10, 12:23 PM
You have a grounding problem, something is not grounded, and the system is backfeeding on itself.
Check carefully all the corner lights, parking lights only on, and then brake lights only, then both together, hopefully that will lead you in the right direction.
I would suspect no ground wires connected on your front turn signal housings.
post #4 of 6 (permalink) Old Mar 10th, 10, 12:27 PM
BILL
SPARKY69's Avatar
check the ground at the headlight switch
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 6 (permalink) Old Mar 10th, 10, 04:42 PM Thread Starter
josh
alright so after a few hrs of connecting cables and checking them I was able to atleast get the brake lights working they light up when the brakes are depressed, a flasher was missing from the fuse box which is why i think the power was just going elsewhere,maybe? I realy dont know about electrical issues but boy are they frustrating.
I have another issue now though. when the headlights are on the brake light is suppose to be illuminated and when depressed it goes brighter. but they dont turn on when the headlights are on they still illuminate when I press the brakes though so atleast I got that far.
thanks for all your help guys
and is it illegal to drive the car in that condition
post #6 of 6 (permalink) Old Mar 10th, 10, 04:58 PM
1. Turn off the headlamps, step on the brake pedal and make a mental note of brightness.
2. Turn on headlights, or parking lights, and notice brightness.
3. If dimmer than brake lights, then tailights are on - normal.
4. Step on brake pedal and notice brightness.
5. If as bright as brake lights by themselves, then its normal, compare results with Step 1.
You want brake lights to be brighter than any other light to tell the driver behind you, you are stopping or slowing down.
Good job by the way. As others suggested, I would wager it was a ground problem along with the missing flasher.
