69 Engine Harness - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 14th, 10, 11:31 AM Thread Starter
69 Engine Harness
Have a 69 Vert and need to see if someone has a schematic of the harness that is in the gutter on firewall.(Have two plugs go to Windshield washer one wire to heater blower and one wire to starter) but have a few that are just dead ended.
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #2 of 14 (permalink) Old Mar 15th, 10, 12:32 PM Thread Starter
Re: 69 Engine Harness
Anyone Please or send me in right direction to locate it
post #3 of 14 (permalink) Old Mar 15th, 10, 01:11 PM
Not a scehmatic per se - what colors are the wires?
BPOS is offline
post #4 of 14 (permalink) Old Mar 15th, 10, 01:39 PM
Kevin
KevinW's Avatar
That harness also has the oil sender, coil wire (resistor wire and 12v from starter) and the starter soleniod wire. The wiring diagrams are in the AIM, do you have one?
Kevin
KevinW is offline
post #5 of 14 (permalink) Old Mar 15th, 10, 01:45 PM
Also a brown tach wire if so equipped
BPOS is offline
post #6 of 14 (permalink) Old Mar 15th, 10, 02:25 PM
click's Avatar
Here is a link to the engine bay wiring diagram. Could also be A/C wires, blower wires... need to know wire colors and sizes.
69CamaroWiringUnderHood
click is offline
post #7 of 14 (permalink) Old Mar 15th, 10, 04:47 PM Thread Starter
No bad on me dont have a AIM.....
Only have one wire(Yellow) to the front plug on wiper should there be 2?
3 wires to the rear plug on the wiper motor
The 3 wires(Blue/Blue/white) pulled to the right(ignore red one) are dead ended and go know where
Purple wire to Starte
Orange wire to blower motor
post #8 of 14 (permalink) Old Mar 15th, 10, 05:16 PM
Jeff
yellow69RS's Avatar
The AIM shows a dark blue going to the oil pressure sender, and another dark blue and a white going to the alternator.
Jeff
yellow69RS is offline
post #9 of 14 (permalink) Old Mar 15th, 10, 07:14 PM
Kevin
KevinW's Avatar
White cloth is resistor, there should be a big loop inside the harness back to the + of the coil. 12 purple: starter soleniod, 14 orange: heater motor, 18 black: wiper motor (single plug), 18 light blue and yellow: wiper motor and pump (double plugs), 20 dark blue: oil sender.
Kevin
KevinW is offline
post #10 of 14 (permalink) Old Mar 15th, 10, 08:18 PM
Disregard the pink and the yellow - added by me.
BPOS is offline
post #11 of 14 (permalink) Old Mar 16th, 10, 10:47 AM Thread Starter
Jeff
that must be for a dummy light?
white was for the old style Alternator?
Thanks that helps alot!
That brownish plug with black/yellow wire is the blue wire right below it?
post #12 of 14 (permalink) Old Mar 16th, 10, 11:26 AM
Yeah, sorry, I zoomed in too close. The dark blue goes into the same plug on the front as the black/yellow.
BPOS is offline
post #13 of 14 (permalink) Old Mar 16th, 10, 04:53 PM Thread Starter
Missing the bottom wire
post #14 of 14 (permalink) Old Mar 17th, 10, 09:35 PM
john
camaro_z28_1969's Avatar
If you need the wiring diagrams for the '69, look in my webshots albums listed in my signature.
Good luck,
john
1969 Z/28 - owned since 1971 - garaged since 1985 - in process of restoring it
camaro_z28_1969 is offline
