Fuel sender shorted - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 14th, 10, 05:44 PM Thread Starter
Fuel sender shorted
just ainstalled a new fuel tank and sending unit. added 10 gallons of gas and gauge reads empty. its an aftermarket sending unit. the gauge was working finebefore i change the sending unit. (tank was leaking) now the sender reads a .7 ohms form brown wire to its ground. any ide3as?
Dave69Z is offline
post #2 of 8 (permalink) Old Mar 14th, 10, 06:34 PM
Greg
Re: fuel sender shorted
I'f you're sure you didn't pinch a wire, and it is <1 ohm with the sender wire unattached to the harness taht runs to the gauge, my guess would be that the float arm is jammed/torqed/stuck.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #3 of 8 (permalink) Old Mar 15th, 10, 04:48 AM Thread Starter
How can i tell if its stuck?
Dave69Z is offline
post #4 of 8 (permalink) Old Mar 15th, 10, 07:49 AM
Greg
Re: Fuel sender shorted
Not what you want to hear, but if you read ~0 ohms at the sender unit end wire, with the harness disconnected, you have to pull the tank and take out the sender to analyze.
1969 RS/SS Vert
chops is offline
post #5 of 8 (permalink) Old Mar 15th, 10, 08:50 AM Thread Starter
unfortuantely your correct. i may try to see if the float is visible, just to see the position. gotta love aftermarket parts.
Dave69Z is offline
post #6 of 8 (permalink) Old Mar 16th, 10, 05:01 AM Thread Starter
It appears float is stuck in the down position or sunk. I can see it thru the opening and it is not floating.
Dave69Z is offline
post #7 of 8 (permalink) Old Mar 16th, 10, 06:06 AM
The first new sender I installed, the $49 repro unit from Rick's, did the same thing (arm stuck down). It could not be fixed, and I bought the $99 replacement from Spectra, which worked fine.
So, if you bought the cheap unit, you're probably out of luck...
Eric
Eric Kammerer is offline
post #8 of 8 (permalink) Old Mar 16th, 10, 07:08 AM Thread Starter
i was afraid of that. that is the one i bought and place i bought it from.
Dave69Z is offline
