Funky Voltage Gauge - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 16th, 10, 07:09 AM Thread Starter
Charlie
Funky Voltage Gauge
Here's one for you. Today my alt went up so I replaced it. Now my gauge won't read battery voltage. It reads charging voltage, but not battery voltage. I have a relay in the system becaue of the way my gauge is wired. I replaced the relay and still no battery voltage. What do you guys think? I get 14.7 at the alt post and 14.7 at the gauge wire, but I get 12.5 at the batt pos term, the junction block and the buss bar. The horn relay/buss bar is new. All these issues started when the alt went out this morning.
67CamaroRS/SS is offline
post #2 of 3 (permalink) Old Mar 16th, 10, 02:57 PM
Re: Funky Voltage Gauge
Sounds like the alternator isn't grounded good. Measure between the alternator shell and the battery (-). Should be a very small voltage - nearly zero. I'll be you'll find your 14.7v there.
dnult is offline
post #3 of 3 (permalink) Old Mar 17th, 10, 05:03 AM Thread Starter
Charlie
I found it. The feed wire from the main harness to the alt has separated. All is good now. Thanks.
