Ground location - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 19th, 10, 08:03 PM Thread Starter
andrew
Ground location
Getting close to finishing my aaw rewire. Quick question for you all. Where do you ground your cars? So far I have only found two locations on my car. One is from the battery to the block and the other is from the frame to the firewall. This does not seem like enough to me. Where else should I put grounds? Also what should I use to do this? Thanks for all your help. I think I'm finally close to getting the car on the road!
chidester is offline
post #2 of 10 (permalink) Old Mar 19th, 10, 08:34 PM
Re: Ground location
That should do it. The entire car is metal, so it is all one big ground.
ggkeller is offline
post #3 of 10 (permalink) Old Mar 19th, 10, 08:35 PM
Jeremiah
Re: Ground location
My original 69 Vert has one o each side of the rear engine to the firewall.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #4 of 10 (permalink) Old Mar 19th, 10, 08:37 PM
Re: Ground location
Oh, I misread your question. There is a second pigtail ground wire on the battery cable that attaches to the right fender near the battery.
ggkeller is offline
post #5 of 10 (permalink) Old Mar 19th, 10, 09:44 PM
Roger
rogerh's Avatar
Re: Ground location
Isn't there a ground strap from the valve cover bolt to the firewall?
Roger
rogerh is offline
post #6 of 10 (permalink) Old Mar 19th, 10, 10:55 PM
Larry
larryh56's Avatar
Re: Ground location
Roger
There is on my car. What year are you working on Andrew? The original ground straps are like these for a 69: http://www.rickscamaros.com/product....5&dept_id=3103
If you have gauges there should be a ground for them, a ground for your coil, and some under the dash. A wiring diagram is pretty handy to look at.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #7 of 10 (permalink) Old Mar 20th, 10, 04:09 AM
Re: Ground location
Roger
Radio equipped cars only
Sauron67MM is offline
post #8 of 10 (permalink) Old Mar 20th, 10, 04:50 AM
Kevin
KevinW's Avatar
Re: Ground location
There are actually 4 on 69s, 2 straps from valve cover to firewall (-1 if radio delete), one from subframe to firewall under heater box and one from subframe to pass inner fender under batt. The battery cable should also have a pigtail to attaches to the pass fender next to battery. All ground wires that attach to the body must be free of paint, rust, dirt to work properly. An often overlooked task after a nice thick repaint.
Kevin
KevinW is online now
post #9 of 10 (permalink) Old Mar 20th, 10, 11:49 AM
Re: Ground location
The primary ground is from the battery (-) to the block. This is so the starter motor gets a solid return current path (which carries hundreds of amps). The other ground is a short fusable pig-tail lead from the battery (-) to the right fender. This is the ground that carries most other vehicle power returns (lamps, accessories, etc.) All other grounds are noise suppression grounds (straps from frame to engine or firewall).
dnult is offline
post #10 of 10 (permalink) Old Mar 20th, 10, 12:12 PM
DjD
DjD's Avatar
Re: Ground location
Roger
Sums it up well! As a side note: I drove my '69 for a year or more with just the ground from the batt to the engine and never had a problem. I only hooked up the fender ground because Charley (clill) was giving me a bad time about it...
...Dennis
DjD is offline
