67 RS Headlight problem (Help) - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 21st, 10, 04:22 PM Thread Starter
I just got my RS/SS back from the paint shop, and have been putting the car back together. NOW, I can't get the Headlights to Close or even move.
When I took the car apart, the headlight motors worked perfect. They seem to be wired correct. When I removed them I took them out in the OPEN position.
Any sugestions?
1967 RS/SS 396 4 Speed (All Stock)
Journey is offline
post #2 of 7 (permalink) Old Mar 21st, 10, 08:04 PM
Russ
rafbody's Avatar
Re: 67 RS Headlight problem (Help)
Have you bench tested them to see if the motors still work? Taking them out in the open position shouldn't matter.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #3 of 7 (permalink) Old Mar 21st, 10, 08:19 PM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
did you tightened the clutch screws to tight ?
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #4 of 7 (permalink) Old Mar 22nd, 10, 04:45 AM Thread Starter
I have not tested them, and I have not tightened anything to tight. When I removed them, all I did was removed the 4 bolts and pulled it straight out.
There is 3 total plugs going to the unit, the 2 wire plug on the back, and the 2 single wires that goes on a small relay on the front. kind hard to get the 2 single wires backwards because of the length,,,,,, any sugestions?
How would I test from here?
Journey is offline
post #5 of 7 (permalink) Old Mar 22nd, 10, 06:00 PM Thread Starter
Thanks Camaro67_rcl
With the diagram you sent me I was able to track down my problem. The R2 Relay has a short in it.
Thanks again,
Journey is offline
post #6 of 7 (permalink) Old Mar 22nd, 10, 06:43 PM
Jeremy
Do you have the ground wires hooked up?
67 Camaro
makoshark is offline
post #7 of 7 (permalink) Old Mar 23rd, 10, 07:43 PM
Rick
Originally Posted by Journey View Post
Thanks Camaro67_rcl
Thanks again,
Glad I could help
Rick
