69 Courtesy lamp harness - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 22nd, 10, 02:11 PM Thread Starter
DT
Donny
DT's Avatar
Do all 69's have the plug to add the underdash courtesy lamp option?? If yes, where exactly is this plug.?? Several searches reveal it may be by the fuse box ??? I can't find it. Thanks.
DT is offline
post #2 of 11 (permalink) Old Mar 23rd, 10, 12:28 AM
cb
Send a message via Yahoo to flyingskibiker
Re: 69 Courtesy lamp harness
I have read that if it is there, it may be behind the kick panel where the rear harness is routed.?.?
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #3 of 11 (permalink) Old Mar 23rd, 10, 05:43 AM Thread Starter
DT
Donny
DT's Avatar
OK thanks for the reply. I will check.
DT is offline
post #4 of 11 (permalink) Old Mar 23rd, 10, 01:26 PM
Roger
rogerh's Avatar
If a 69 is anything like a 67 it should look like this. This is the wiring harness that goes back to the rear lights and dome light. This is located behind the left kick panel. Notice the hinge plate to the left and the vent opening to the right. The wiring that is going down is the harness we are talking about. That connector at the top with the orange and white wires coming out of it is the courtesy light connection.
Roger
rogerh is online now
post #5 of 11 (permalink) Old Mar 23rd, 10, 03:05 PM Thread Starter
DT
Donny
DT's Avatar
Awesome pic Roger Thanks. Unfortunately, I do not see any orange and white wires going down behind the kick panel. I do see a White single wire which is for the door jamb switch.
DT is offline
post #6 of 11 (permalink) Old Mar 23rd, 10, 05:30 PM
Roger
rogerh's Avatar
The orange and white wires are going to the under dash courtesy lights. They are plugged in to the female connector you are looking for. The single white wires are going the the door switches. If you don't have the under dash lights you wouldn't have the orange and white wires.
Roger
post #7 of 11 (permalink) Old Mar 24th, 10, 07:29 PM Thread Starter
DT
Donny
DT's Avatar
Thanks Roger, I just have to figure out how to gently remove the kick panel without damaging it.
DT is offline
post #8 of 11 (permalink) Old Mar 25th, 10, 02:59 AM
mark
mark x22's Avatar
the under dash lights use a different harness .http://www.rickscamaros.com/product....dept%5Fid=3134
mark x22 is offline
post #9 of 11 (permalink) Old Mar 25th, 10, 05:50 AM Thread Starter
DT
Donny
DT's Avatar
Thanks Mark, the harness I need costs around 32.00. It is for the underdash lights only. It plugs in somewhere by the drivers kick panel.
DT is offline
post #10 of 11 (permalink) Old Mar 25th, 10, 12:56 PM
Roger
rogerh's Avatar
There is no easy way to get that kick panel off. The E-brake pedal needs to be remover to get it out. That connector should be at the top of the kick panel and you may be able to access it without removing the panel.
Again remember the 69s may be completely different then my 67. Is you courtesy light harness a multi year (67-69) harness?
Roger
post #11 of 11 (permalink) Old Mar 25th, 10, 02:59 PM Thread Starter
DT
Donny
DT's Avatar
I think they are all different.
DT is offline
