Wiper Motor and FUSE!!! - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 25th, 10, 05:24 PM Thread Starter
Vic
Angry Wiper Motor and FUSE!!!
I am having an issue with my wiper and the fuse! When the transmission arm is not on the motor, the motor turns, but when i mount the transmission arm, put the screw on and hit the switch, it does like a half *** turn and the fuse trips! any idea whats going on, and how to fix?
Vic
1969 Camaro SS
Camaro1969 is offline
post #2 of 7 (permalink) Old Mar 25th, 10, 05:28 PM
Keith
Re: Wiper Motor and FUSE!!!
You need a new wiper motor...It is turning Ok wihtout the arm because it doe snot need to "pull" that much power. When you put a load on it, it draws more heavily.
A new wiper motor will cure what ailes you...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #3 of 7 (permalink) Old Mar 25th, 10, 07:12 PM Thread Starter
Vic
10 amp fuse, what if i increase the fuse amperage, will it just burn out the motor?
Vic
1969 Camaro SS
post #4 of 7 (permalink) Old Mar 25th, 10, 07:27 PM
Keith
If the circuit calls for a 10 amp fuse, placing a large fuse in the circuit could cause a fire...(I had a '77 Nova with a bad wiper motor, that I used wire to "jump" the circuit (bypass the fuse), and ended up nearly setting the car on fire! ( My only excuse is that I was 17 and thought I knew better than the guy that told me to replace the wiper motor)!
Bottom line is:
Don't upsize the fuse to correct an issue with the component...the fuse is meant to prevent the circuit from overheating, burning the wires and starting a fire. Use the fuse specificed for the application--if it continues to blow, it is alerting you that there is a problem in the circuit that needs to be remedied...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #5 of 7 (permalink) Old Mar 25th, 10, 09:27 PM Thread Starter
Vic
thanks keith, you put it in perception, ill go get a motor tomorrow!
Vic
1969 Camaro SS
post #6 of 7 (permalink) Old Mar 25th, 10, 10:26 PM
i got one at autozone 59.00
anthony hisle is offline
post #7 of 7 (permalink) Old Mar 26th, 10, 04:31 AM
Keith
also, make sure all of the linkage for the wipers moves freely when you install the new motor...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
