Brake light/ turn signal problem - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 27th, 10, 05:16 PM Thread Starter
keypilot's Avatar
ok, when i hit the brakes they light up correctly. when I turn on the parking lights and hit the brake they also work properly. if I hit the turn signal it flashes correctly but together with the brake I only have the turn signals. no brake lights.
if the paking lights are on and i hit the turn signals one side flashes and the other is steady, but step on the brakes and nothing changes.
I am super confused
any ideas on where to start? I was thinking there may be a problem with the turn switch.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
post #2 of 9 (permalink) Old Mar 27th, 10, 05:21 PM
Skip
Skeeter55's Avatar
Re: brake light/ turn signal problem
Mark....... Everett is the man for this.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 9 (permalink) Old Mar 27th, 10, 05:24 PM Thread Starter
keypilot's Avatar
thanks Skip.
EVERETT!! WHERE ARE YOU AT????? lol
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #4 of 9 (permalink) Old Mar 27th, 10, 08:52 PM
Re: Brake light/ turn signal problem
Sounds like the turn signal switch as brakes go through the t/sig switch.
You might jiggle the t'sig handle to see if one function comes back. T/sig switches do wear out.
Of course, you've checked to make sure the correct bulbs are installed and everything was working before.
post #5 of 9 (permalink) Old Mar 28th, 10, 07:47 AM
Skip
Skeeter55's Avatar
Also check the wiring harness under the steering column to make sure the pins all have a good connection.
post #6 of 9 (permalink) Old Mar 28th, 10, 08:42 AM Thread Starter
keypilot's Avatar
thanks. I have a birthday in a few weeks and I have made a wish list (as asked by my wife). an ididit colum is at the top, along with the phone number to order it and the exact info needed , so I will let this problem sit for a couple of weeks.
on a seperate issue, does anyone know where i can get the connectors for the dome light bulb? mine are corroded and not making good contact. I tried napa but they were useless. I dont need the fixture, just the electrical connectors that hold the bulb.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #7 of 9 (permalink) Old Mar 28th, 10, 09:11 AM
DT
Donny
DT's Avatar
Mark, Ive asked the same exact question in an earlier thread, regarding the Dome Light terminals. No responses.
https://www.camaros.net/forums/showthread.php?t=176403
DT is offline
post #8 of 9 (permalink) Old Mar 28th, 10, 03:48 PM Thread Starter
keypilot's Avatar
Donny, I sent an email to ricks, i will let you if they answer.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #9 of 9 (permalink) Old Mar 28th, 10, 04:27 PM
DT
Donny
DT's Avatar
Excellent Mark, thanks. I sent several e-mails out, even to Factory Fit, all came back No Good.
DT is offline
