Alternator plug - where can I get one? - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 28th, 10, 07:52 AM Thread Starter
Any ideas where I can get the plug for the back of a 69 alternator - the one with 2 wires to the regulator? Don't want an entire harness, just the plug with long enough leads to connect to my existing harness.
Thanks, Steve
69 Pace Car and 69 Hard top
srode is offline
post #2 of 7 (permalink) Old Mar 28th, 10, 08:53 AM
Re: alternator plug - where can I get one?
I'm not sure, but I got the plug for my CS-130 at the auto parts store in the HELP section. So give that a try.
dnult is offline
post #3 of 7 (permalink) Old Mar 28th, 10, 10:06 AM
Greg
I just cut mine off my factory harness.
I bought one for the 12si at AutoZone so I feel sure they have the style you need also.
Are you changing the alternator?
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #4 of 7 (permalink) Old Mar 28th, 10, 10:31 AM Thread Starter
I'm replacing it because it has some bearing noise, but thinking going back with the same. I was thinking about switching to an internal regulated one - but can't find one with the hole in the back for the spacer to bolt to like the original external regulated one so may stick with an external regulated. I'll check with Autozone tomorrow on my way home from work.
srode is offline
post #5 of 7 (permalink) Old Mar 28th, 10, 11:59 AM
Steps
It is not hard to replace the bearings and while at it the bushes.
good move covered in detail in many old threads
Plugs, check out local car wreaking yards...
Steptoe is offline
post #6 of 7 (permalink) Old Mar 28th, 10, 02:23 PM
Got mine at the local Parts store...$5 ??? maybe.
68 Camaro~LSx ~all motor
post #7 of 7 (permalink) Old Apr 25th, 10, 06:03 PM
ern
ern
classic industries has the short harness to convert from old harness to new ,hope this helps
ern is offline
