MSD 6AL Problem - Need some Help! - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 28th, 10, 02:42 PM Thread Starter
Purchased an MSD ignition system off of Ebay, maybe my first mistake, and have a problem, no power to the coil when switch is on. The ignition is a MSD 6AL, Pro-Billet dual-pickup distributor, and Blaster 2 coil. I have everything hooked up and triple checked the wiring. I have power coming to the unit from the battery and when the switch is on. I don't have power to the coil, which want run the engine. Coil is good because I used it to run the engine with old setup.
Any ideas?
1968 RSSS BB 396/325 AC TH-400 Black/Red (Sold)
1969 Nova SS 350 M-20 Red/Black (Original)
1967 Chevelle SS (Clone)(Project)
tim68rsss is offline
post #2 of 2 (permalink) Old Mar 28th, 10, 03:20 PM
Derek
Dereka's Avatar
Re: MSD 6AL Problem - Need some Help!
check the trouble shooting guide on their web site. i think you ground the white wire to check spark to determine if the box is good. but check with them first to make sure.
Dereka is offline
