Brake pedal lights left turn signal? Suggestions? - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 31st, 10, 07:22 AM Thread Starter
Greg
Any specific place(s) I should look, things I should unplug/clean/replug? Anybody had and solve this problem before? Thanks gents. '68 BTW, plain jane......
Greg
greg1ontheedge is offline
post #2 of 10 (permalink) Old Mar 31st, 10, 08:35 AM
Re: Brake pedal lights left turn signal? Suggestions?
Check all your lighting grounds, do not forget front parking light grounds, sounds like a feedback.
john68 is offline
post #3 of 10 (permalink) Old Mar 31st, 10, 01:17 PM Thread Starter
Greg
Thanks for taking time to reply John. I didn't think about the front parking lights. Appreciate your suggestions my friend...........
Greg
post #4 of 10 (permalink) Old Mar 31st, 10, 03:01 PM
My 68 did that in 71, my boss a tad me put a turn switch it it, didn't help, talked to a old man, touched one ground wire, 30 seconds, fixed, wasted 50 dollars and a day.
john68 is offline
post #5 of 10 (permalink) Old Mar 31st, 10, 04:43 PM Thread Starter
Greg
Again appreciate you chimin in. I'll be honest, I don't know a ground wire from a hot one. I checked all the wiring and it's secure and screwed down (where applicable). The parking lights come on when I turn my lights on, as they should. The trun signals work in both directions. It's just when I push the brake pedal, the rear brakes lights work fine but the left front turn signal light comes on and the left trun signal on the speedo comes on. Both go off when you let off the pedal so it's obviously connected. Would you have any specific things wires, I should check? I assume it can't be anything much but I'd sure like to find and fix it.....
Thanks again John....
Greg
post #6 of 10 (permalink) Old Mar 31st, 10, 05:55 PM
Push up, towards the dash, slightly on the turn signal lever. Could be the t/sig switch is worn out.
As John suggested, check the ground wire at the front parking light, the black wire coming out of the socket and is bolted to the radiator support. Remove ground and wire brush both the terminal and rad support. Reassemble.
post #7 of 10 (permalink) Old Mar 31st, 10, 06:08 PM Thread Starter
Greg
Thanks Everett. Pushing up is the right turn signal, it's the left that comes on when brake pedal is pressed. Am I missing something? What should I expect to happen, or not happen? Appreciate your help...
Greg
post #8 of 10 (permalink) Old Mar 31st, 10, 11:47 PM
cb
Send a message via Yahoo to flyingskibiker
The brake switch wire does route into the turn signal switch harness connector... Maybe a short in that area?
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #9 of 10 (permalink) Old Apr 1st, 10, 03:16 AM
You're not to push it up to rt turn, just push gently up on the handle within its center/off position. Also, pull up on the handle, as in pull gently towards the steering wheel.
Brake light power does go through the t/sig switch.
post #10 of 10 (permalink) Old Apr 1st, 10, 06:13 AM Thread Starter
Greg
Thanks for the add Everett, much appreciate all the help.....
Greg
