Battery in trunk, now starter drags - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 1st, 10, 11:28 AM Thread Starter
I mounted my battery in the trunk and now after I drive for a while and shut it off it won't start. It acts like the battery is dead. I had it checked ( the battery) and even tried another one. The alternator is putting out between 12.5 and 14 volts. Could the wire going to the starter from the battery be too small. Also, I have the wire to the alternator going directly to the starter, is that ok.
edcorsaro is offline
post #2 of 8 (permalink) Old Apr 1st, 10, 12:47 PM
Steps
Re: Battery in trunk now starter drags
Yep..you cant use normal battery ccable...with such high currents u get voltage drop which also means power drop. VxA=W
We used to use Arc welder cable on race cars.
Steptoe is offline
post #3 of 8 (permalink) Old Apr 1st, 10, 01:09 PM
This should give you an idea of your present design flaws. It'll never work properly unless you wire it correctly. http://madelectrical.com/catalog/tm-1.shtml
Sauron67MM is offline
post #4 of 8 (permalink) Old Apr 1st, 10, 02:02 PM
Greg
How is it grounded? I had to add 2 or 3 ground straps after I moved my battery. Battery to fram, frame to body, frame to engine...you get the idea.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #5 of 8 (permalink) Old Apr 1st, 10, 02:18 PM
Best to run dedicated ground directly to block.
post #6 of 8 (permalink) Old Apr 1st, 10, 04:51 PM
Vall
Amen! That's the most common error on most remote battery installations. Poor grounds.
1971BB427 is offline
post #7 of 8 (permalink) Old Apr 2nd, 10, 03:31 AM
Steps
And again
Plus a short one from the battery to somewhere close on the body.
Steptoe is offline
post #8 of 8 (permalink) Old Apr 2nd, 10, 01:19 PM
Re: Battery in trunk, now starter drags
Copied and pasted from the above linked "mad" site:
The battery ground (NEG) is connected to the car body at the rear. And up front, another short length 1/0 cable connects from body to the engine. This system uses the car body for the long intermediate length of the NEG side of the system all the way to the engine. (It’s actually more efficient than routing a heavy gauge cable all the way forward to the engine.)
BPOS is offline
