69 Camaro front valance lights - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 1st, 10, 10:12 PM Thread Starter
Jerry
He guys can someone help me out. When the body shop returned the car from paint, I needed to run the wiring for the lower valance lights (amber) Does anyone have a photo of the correct routing? Also does anyone know where to purchase the wiring clips that hold the wiring in place? and where they mount....I did not remove them and it has been 2 years in the making....any help would be great.....Thanks.
CAMARO GUY is offline
post #2 of 9 (permalink) Old Apr 2nd, 10, 04:43 AM
Kevin
KevinW's Avatar
Re: 69 Camaro front valance lights
Camaro guy (name?), the clips mount to the underside of the large bumper supports and can be bought from the catalogs (they recently have been reproed). There should be a rubber plug that goes into a hole in the inner fenders near the ends of the rad support.
So, just insert the rubber plug, then plug into wiring harness females and then clip the wire into the clips from the bottom of the support. The light housing needs the ground to function, so make sure you have good grounds through the sheetmetal to the housing (use ohm meter)
Kevin
KevinW is offline
post #3 of 9 (permalink) Old Apr 2nd, 10, 08:22 PM Thread Starter
Jerry
Kevin,
Thanks for the information. Do you know who sells them? I cannot seem to locate them.
Thanks,
Jerry
post #4 of 9 (permalink) Old Apr 3rd, 10, 05:27 AM
Kevin
KevinW's Avatar
Jerry, here they are, aint cheap http://www.rickscamaros.com/product....&dept%5Fid=999
Camaro Parking Light Harness Retainers, 1969
Reproduction Of Original
Technically Correct
Commonly Broke, Rusted Or Missing
Made In USA
Item# PK-80
$32.99 pr.
Kevin
KevinW is offline
post #5 of 9 (permalink) Old Apr 3rd, 10, 08:21 AM
"Tri-Tip"
Gary L's Avatar
Some one else has to sell them too. I need a pair.
Gary L is offline
post #6 of 9 (permalink) Old Apr 3rd, 10, 09:22 AM
prostreet69camaro's Avatar
That price is redicilous. But if they are the only ones that have them you will pay that.
prostreet69camaro is offline
post #7 of 9 (permalink) Old Apr 3rd, 10, 10:55 AM
Eke
James Brown
I saw some on ebay that were much more reasonable but can't remember who had them. If I find them I'll post the link.
69 RS - Total Nut & Bolt Rebuild began 9/6/07
Eke is offline
post #8 of 9 (permalink) Old Apr 3rd, 10, 02:10 PM
"Tri-Tip"
Gary L's Avatar
Only $28.95 here.
Gary L is offline
post #9 of 9 (permalink) Old Apr 3rd, 10, 07:14 PM Thread Starter
Jerry
To make matters worse I have found one.....Now I will need to buy 2......unless anyone has one they would like to part with for the right price?
