Front Light Harness - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 2nd, 10, 07:19 PM Thread Starter
Greg
Front Light Harness
Need Help, Just put in a new engine harness from American Auto Wire and it went in nice and easy. Now I am putting in the front light harness and need help with a few wires. Its a 69 small block 350 (non original) ,4 speed with HEI. A one wire Alt with internal regulator on the passenger side. From the fuse box I got temp sending,side markers,black grounds,horns, horn relay and lights all OK. near the end about 2 ft is a red wire with circle hole connector, Does this go to the junction block ? If not where ? At the end is a heavy red wire with circle hole connector and black rubber cap Where does this go ? Last is two wires, red and brown hooked to a double connector, where does this one go ? Your help is appreciated. Thank You.
69-454 is offline
post #2 of 8 (permalink) Old Apr 2nd, 10, 07:57 PM
Re: Front Light Harness
I suggest the red wire with the black cover goes to Alternator BAT stud and its other end to the junction block by the battery to charge battery and provide electrical power for the rest of the car.
Not a clue on the brown & red wires. Wait, these are the sense and excite wires for the internal regulated alternator, red to #2 (sense wire from a power distribution point - horn relay buss bar?), brown to #1 (comes on with ign switch on IGN).
post #3 of 8 (permalink) Old Apr 2nd, 10, 08:12 PM Thread Starter
Greg
Thank you, I found a place on the Alt where the red and brown will plug in. I am still confused. I agree the red one with the cover should go to Alt batt. But there is no other end it goes into the harness. I thought the other end of this red one went to the positive side of the battery . Is this where the other red one about two feet shorter comes in. If they both hook to the junction block will the Alternator charge make it to the battery ?
69-454 is offline
post #4 of 8 (permalink) Old Apr 3rd, 10, 01:04 AM
i would say to the little black junction block by the battery
anthony hisle is offline
post #5 of 8 (permalink) Old Apr 3rd, 10, 05:49 AM
Both large gauge red wires should go to junction block as Anthony suggests along with positive cable pigtail.
There may be a red wire from the horn relay to junction block - measure for continuity.
Measure from alt BATT to horn relay buss bar - measure for continuity.
I don't have a '69 wirting diagram in front of me, but, the wire route would be from alt to j/block, or from alt to h/relay then to j/block.
Then pos cable pigtail to j/bock. After wire hook up and before clamping onto battery, measure continuity from alt BATT stud to pos cable cable - if good - cool!
post #6 of 8 (permalink) Old Apr 3rd, 10, 08:30 AM Thread Starter
Greg
You are right , the shorter red wire is from the horn relay and I will hook it to the junction block, Then I will put the positive battery cable to the starter and the small red battery positive to the junction block. The long heavy red wire fits perfect for length and hook up at the alternator . One more question, do I need to run a wire from the alt to the positive battery. ( one wire for charging ) ? If not where does the battery get its juice from the Alt ?
69-454 is offline
post #7 of 8 (permalink) Old Apr 3rd, 10, 08:30 PM
No need to add a second wire, the red wire from alt goes to the horn relay to junction block to battery post/clamp.
post #8 of 8 (permalink) Old Apr 4th, 10, 06:57 AM Thread Starter
Greg
Thank you for your advice on the continuity tester and the hook up. I think we got it. Thank you.
69-454 is offline
