Turn indicators on dash don't illuminate - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 3rd, 10, 06:10 PM Thread Starter
bobfabie
Unhappy Turn indicators on dash don't illuminate
I need your help, please. 1968 camaro. Everything works, but the turn indicator arrows on the dash DO NOT illuminate. I hear the flasher and the exterior turn signals work, but no dash indicators. 4 way flasher also work, but the dash indicators don't illuminate. Both bulbs are good. All other bulbs/indicators on the cluster work. THANK YOU!!
bobfabie is offline
post #2 of 5 (permalink) Old Apr 22nd, 10, 07:04 AM
Re: turn indicators on dash don't illuminate
have you recently replaced or removed the dash carrier assembly?
If so, check your grounds.
I had the same problem
brianstevens03 is offline
post #3 of 5 (permalink) Old Apr 24th, 10, 05:49 AM Thread Starter
bobfabie
Thanks for the response. Yes, I very recently R&Rd the cluster and I will remove it again to check the grounds. I overlooked the obvious. Thanks again.
bobfabie is offline
post #4 of 5 (permalink) Old Apr 27th, 10, 06:08 PM
cb
Send a message via Yahoo to flyingskibiker
Re: Turn indicators on dash don't illuminate
What was the result? I have the same problem. It happened after I tried to get my horn working again. All my lights work, just the turn indicators don't... I figured I burned up the circuit board?
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #5 of 5 (permalink) Old May 7th, 10, 01:09 PM Thread Starter
bobfabie
Sorry guys. Have gotten busy with work and have not removed my instrument cluster to follow up on the suggested remedy (ground). I'm very intrigued that flyingsbiker has the IDENTICAL problem. I'll do my part as soon as I'm back in town. Standby..
bobfabie is offline
