Connecting OER tic-toc-tac for my 68 - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 3rd, 10, 09:49 PM Thread Starter
Nev
I have purchased an OER tic-toc-tac for my 68 Camaro.
There are 3 terminals on the back of the tach.
I assume 2 are for the tach to function and 1 is for the clock.
The terminal at the 12 o'clock position and 8 o'clock position (when looking at rear) are posts that have nuts tightening onto the PCB.
The terminal at the 4 o'clock position does not touch the PCB.
Can anyone advise of correct terminals for connection of the tach.
[IMG][/IMG]
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #2 of 6 (permalink) Old Apr 3rd, 10, 10:47 PM
Larry
larryh56's Avatar
Re: Connecting OER tic-toc-tac for my 68
Check out my post: https://www.camaros.net/forums/showthread.php?t=158264 It includes some wiring harness info but should have what you need. You have the tack and clock labeled correctly. The 8 o'clock is switched power I believe (red wire with white stripe).
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 6 (permalink) Old Apr 3rd, 10, 11:55 PM Thread Starter
Nev
Thanks mate.
I wasn't thinking right.
Thought I had to hook up to those posts at 12 o'clock and 8 o'clock.
But of course you must be right that the power and signal come through the plug behind the speedo and via the PCB to the Tach.
I'll give it a go and give you an update tomorrow.
Thanks for your help.
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #4 of 6 (permalink) Old Apr 10th, 10, 09:18 PM Thread Starter
Nev
Originally Posted by nev68 View Post
Thanks mate.
I've connected the aftermarket (Autometer) console guages and everything works.
Fitted the tach (Tic-toc-tac) and I have the clock working but the tach doesn't work.
How do I check the tach is OK?
Can I bypass the wiring and hook it directly to the HEI distributor?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #5 of 6 (permalink) Old Apr 10th, 10, 11:25 PM
Larry
larryh56's Avatar
Your welcome and yes you could hook the tach directly to the distributor. However you may want to check to make sure you have the wiring correct first. Is it a GM HEI? Do you have anything else connected like a MSD box? Is it connected to the tach pin in the cap? I am running a separate coil so it is easy to make sure it is on the -ve post. You could test the wiring for continuity between the tach and distributor. Be careful you don't want to fry your new tach!
Samuel Adams
larryh56 is offline
post #6 of 6 (permalink) Old Apr 10th, 10, 11:58 PM Thread Starter
Nev
Hi,
I've been through the wires several times just to check if the wiring is correct.
It seems to be OK to me when compared to the diagrams I have. (but I'm no expert)
I have a MSD HEI distributor and the tach wire appears to be connected and I can get a circuit (checked with multi meter) all the way to the PCB connector.
I am with you, I don't want to fry the new tach so I'll have to get an expert involved.
Thanks for your input.
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
