67 fuel gauge reads past full - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 6th, 10, 02:37 PM Thread Starter
I have a 67 that the fuel gauge was kind of working it would bounce around while driving. The other day my wife went and filled up the tank and now it reads past full even after driving for 60 miles.
Sassy67 is offline
post #2 of 6 (permalink) Old Apr 6th, 10, 04:36 PM
Re: 67 fuel gauge reads past full
Sending unit could be stuck in the full position. Normally, gauge will read about 3-4 marks passed FULL.
But after driving 60 miles, assuming 15 MPG, gauge should read around 1/2-5/8 full/empty. Might slap the dash........
post #3 of 6 (permalink) Old Apr 6th, 10, 04:43 PM
Skip
Skeeter55's Avatar
Hey Everett!!!
What would cause it to read past the full mark like mine does and at empty it reads 3/4... Ive tried a new gauge (auto meter) and same results. Ive tested the grounds and ohm's which indicate the sender went bad. But over night.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 6 (permalink) Old Apr 6th, 10, 04:47 PM
Originally Posted by Skeeter55 View Post
Hey Everett!!!But over night.
It can happen; 0 ohms empty, 90 ohms full. Might check ground connection.
Get two 45-50 ohm resistors from Radio Shack or TV repair shop.
Both resistors in series, 90-100 ohms full tank.
One resistor in series is half tank.
Both resistors in parallel is 1/4 tank.
This means one resistor lead to the tan wire to gauge, the other resistor lead to ground.
post #5 of 6 (permalink) Old Apr 6th, 10, 04:51 PM
Skip
Skeeter55's Avatar
Thank you Everett.... I will check it out one more time, before i have to drop the tank.
post #6 of 6 (permalink) Old Apr 6th, 10, 04:55 PM
Chris
67RSSS's Avatar
Are you sure the Mrs. did not fill up with Chevrons new "pump stretcher" formula that suposedly doubles your gas mileage?
67 RSSS Van Nuys, 4th week Sept,1966
ps,tilt,headrest,spd warn,pw,am/fm,delux int,
remote mirror,rear defrost,tint glass.etc...
TKO 600 Extreme,12bolt 3:73 gears.
67RSSS is offline
