Ground Wire for electric gauges - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 16th, 10, 02:58 AM Thread Starter
Rob
New electric gages being installed. The instructons say that for the temp and oil pressure gages, the ground lead needs to go to the block. Is there any reason that a firewall ground won't work if the firewall is properly grounded to the block by the strap?
'67 Rag Top, 350, Th 350, Frame off resto to an SS clone
hurdslake is offline
post #2 of 2 (permalink) Old Apr 17th, 10, 12:26 AM
Nev
Re: Ground Wire for electric gauges
The senders for both temp and oil (electric) gauges must be grounded and they will ground through the thread of the sender, so you have to be careful if you use thread sealer or similar.
The ground for the gauge should be OK anywhere you can find a good circuit to ground.
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
