67 RS headlight doors won't close - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 16th, 10, 08:19 AM Thread Starter
Stan
Car had bad headlight motors when I got it. All electronics appeared to be in place and Was getting power to both sides. Rebuilt both sides with new bushings, washers etc. and new motors. If doors are closed and headlight switch is pulled out they will open nicely, but when switch is pushed in they will not close. Any suggestions?
rsss3961 is offline
post #2 of 10 (permalink) Old Apr 17th, 10, 02:32 PM
Roger
rogerh's Avatar
Re: 67 RS headlight doors won't close
Have you checked your e-mail. I e-mailed you some RS info. (wiring diagrams and trouble shooting guide)
Roger
rogerh is online now
post #3 of 10 (permalink) Old Apr 18th, 10, 08:16 AM
Roger can I get a copy of that as well? I sent you a PM
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #4 of 10 (permalink) Old Apr 24th, 10, 12:52 PM
Vance
Send a message via Yahoo to Daltonslam
I could use a copy as well.
Daltonslam is offline
post #5 of 10 (permalink) Old Apr 25th, 10, 02:31 PM
Roger
rogerh's Avatar
Welcome to the site Vance the PDF file is on it's way.
Roger
post #6 of 10 (permalink) Old Apr 25th, 10, 08:05 PM
Thanks again Roger for the file
Brandan is offline
post #7 of 10 (permalink) Old Apr 26th, 10, 06:40 AM
Michael
I have the exact issue with my '67.
I have to supply power (12v) to one of the two prong connectors on relay #2 (or #3 as it is redundant) in order to close the doors. The manual says either the light switch is bad or the diode is missing (or wired backwards).
I suppose it could be the dimmer switch, but my headlights work (highbeams too), but the doors just won't close on their own.
Did you get a chance to work on your doors over the weekend?
mahunt is offline
post #8 of 10 (permalink) Old Apr 27th, 10, 12:26 PM
The doors won't close if the key is switched to OFF.
Also a member of
Blown 67 is offline
post #9 of 10 (permalink) Old Jun 26th, 13, 11:22 AM
Chris
Me and my son are finishing up on a complete build on his 67 Camaro. The headlight doors open fine but will not close. I have been told there are a number of publications needed to find the problems in the system. Do you know where I can find these. I have checked with Classic and D&R out of Chicago nobody seems to know of any trouble shooting guides.
rocketpower is offline
post #10 of 10 (permalink) Old Jun 26th, 13, 12:32 PM
Roger
rogerh's Avatar
Chris, welcome to the site. Check your e-mail.
Roger
