1969 z/28 alternator dos not charge - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 22nd, 10, 02:11 PM Thread Starter
Erick
car as stock alternator and regulator.
Car was not charging, so i purchased a new alternator ... after installing new alternator...still no charge.
Heres what i see; large red wire behind alternator as 12 Volts, little dark blue wire behind alternator as 12 volts, white wire as 0 volts.
I made sure that both white and dark blue wires have continuity between alternator and voltage regulator.
Voltage regulator harness as 12volts on all wires except for brown.
could it be the voltage regulator is no good.
How to check voltage regulator if it functions.
thanks
braz28 is offline
post #2 of 3 (permalink) Old Apr 22nd, 10, 09:14 PM
Re: 1969 z/28 alternator dos not charge
Tell us you didn't turn in the original alternator for a core, did you?
buenymayor is offline
post #3 of 3 (permalink) Old Apr 23rd, 10, 04:11 AM
Kevin
KevinW's Avatar
Probably the battery has a bad cell and doesnt HOLD the charge. Yes if you removed the unique dated originals from your Z and did not save them, expect LARGE $$ to replace them or a big hit in resale price.
Kevin
KevinW is offline
