69 Z/28 console gauge problems - Team Camaro Tech
post #1 of 11 (permalink) Old May 23rd, 10, 04:40 PM Thread Starter
Chris
I just got my Z/28 back from having it restored and I am having trouble with the amp and temp gauges. The lights are not working on these but the bulbs are good. Also when I turn on the headlights, the temp gauge swings full right and stays there until I turn the lights off. I have tried to remove the cluster to check the wiring but I am haveing trouble and I don't want to break anything. Any help would be appreciated. Thank you.
cldcamaro is offline
post #2 of 11 (permalink) Old May 23rd, 10, 07:00 PM
"Tri-Tip"
Gary L's Avatar
Re: 69 Z/28 console gauge problems
I would guess a bad ground is causing your problems. The temp gage should have 12V in and grounds at the sensor in the head.
Gary L is offline
post #3 of 11 (permalink) Old May 23rd, 10, 08:53 PM
john
wagonman's Avatar
I agree,
there should be a ground under the console.is it connected?
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #4 of 11 (permalink) Old May 24th, 10, 08:43 AM Thread Starter
Chris
Gary
Thank you for the reply. Can you offer any info on removing the cluster so I can check the wiring? I noticed that you have a Lemans Blue / Ivory Camaro, I looked at the picture, good looking car. This Z/28 is a Lemans Blue / Ivory Interior and White Vinyl Top.
Thank you
Chris
post #5 of 11 (permalink) Old May 24th, 10, 08:53 PM
Dale
Remove the shift plate (4 screws)
Remove the lense panel covering the gauges (2 screws)
Reach under the console thru the shifter area, there are 2 screws,5/16 heads (I think). Remove them. The picture shows the screws
After removing the rear screws, slide the gauges rearward, lifting at the back.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #6 of 11 (permalink) Old May 25th, 10, 07:44 PM
"Tri-Tip"
Gary L's Avatar
Maybe this will help.
Gary L is offline
post #7 of 11 (permalink) Old May 26th, 10, 10:26 AM Thread Starter
Chris
Thank you for the picture. I will try to get it fixed this weekend.
Chris
Last edited by cldcamaro; May 26th, 10 at 07:42 PM. Reason: I am learning on the site and I am trying to respond to each person that is offering advise
post #8 of 11 (permalink) Old May 26th, 10, 10:29 AM Thread Starter
Chris
Thank you. I will try to get it fixed this weekend. I have been working in this car for two years and have a few little things to complete. I can't wait to drive it to a few shows and have some fun with it.
Chris
post #9 of 11 (permalink) Old May 26th, 10, 10:31 AM Thread Starter
Chris
Thank you. I will try it this weekend.
Chris
post #10 of 11 (permalink) Old May 26th, 10, 07:25 PM Thread Starter
Chris
Gary,
The cluster came out fine and I found that the ground wire from the tunnel bracket runs to a bottom post under the fuel gauge. I connected a temperary wire to the tunnel bracket and then to the housing of the temp gauge and the amp meter and the console lights to the rear gauges worked fine. Should I run a permanent wire to the housing or to one of the four terminals on the temp gauge? Thank you Chris
post #11 of 11 (permalink) Old May 26th, 10, 07:37 PM Thread Starter
Chris
Thank you, it worked fine. Chris
