Horn troubleshooting - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 27th, 10, 05:48 AM Thread Starter
If I put a meter between the red and black wires at the horn relay should I see a voltage? Where does the black wire go to? I definitely have voltage to the red wire but nothing when I measure between the two.
Any help is appreciated.
71LT-1 is offline
post #2 of 2 (permalink) Old Jul 1st, 10, 01:43 AM
Re: Horn troubleshooting
The black wire goes to your horn button where it is grounded to switch on the horn. That means your black and red wire are both seeing 12V. You shouldn't see voltage between the two.
If you ground the black wire, does your horn work?
BlackoutSteve is offline
