Need help my car is wired but no volt. Reg and horn relay - Team Camaro Tech
post #1 of 11 (permalink) Old Jun 29th, 10, 10:24 PM Thread Starter
Banned
garay77n84's Avatar
Help.. I just bought a 67 camaro all lights,blinkers,wipers work..but there is no horn relay or voltage regulator..some wires have been cut at the firewall.. I have located the power wire and the starter wire..any help would be appreciated
garay77n84 is offline
post #2 of 11 (permalink) Old Jun 29th, 10, 10:30 PM
class67's Avatar
Re: Need help my car is wired but no volt. Reg and horn relay
Is it factory wiring? or a kit? some kits have everything built into the fuse block...
67 Camaro RS
class67 is offline
post #3 of 11 (permalink) Old Jun 30th, 10, 03:38 AM
Need more info.......is there an alternator?
Type of alternator?
GEN light go out after engine is started?
Horn work?
As you measure charging voltage across battery posts, is it 14 volts?
What's the condition of the car?
Battery in the trunk?
post #4 of 11 (permalink) Old Jun 30th, 10, 04:05 AM Thread Starter
Banned
garay77n84's Avatar
sorry factory wiring
post #5 of 11 (permalink) Old Jun 30th, 10, 04:07 AM Thread Starter
Banned
garay77n84's Avatar
Type of alternator?
Horn work?
no motor at all...car has been frame off and every single panel that could be be replaced ..has been replaced
post #6 of 11 (permalink) Old Jun 30th, 10, 04:55 AM
So you're asking for what to do with the missing pieces and how to wire them up?
post #7 of 11 (permalink) Old Jun 30th, 10, 05:51 AM
Greg
If "some wires have been cut", the best advice I can give you is start with purchasing the chassis manual with wiring diagram. It is a super easy diagram.
You have to address 40 years worth of wires getting hacked and get it back to an original state.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #8 of 11 (permalink) Old Jun 30th, 10, 06:11 AM Thread Starter
Banned
garay77n84's Avatar
exacatly....the wires are cut and only have about 8" of wires hanging out from the firewall fuse box connector....they are color coded
post #9 of 11 (permalink) Old Jun 30th, 10, 07:08 AM
click's Avatar
Get the AIM Assembly Instruction Manual, it has the wiring diagrams you will need to redo it all.
click is offline
post #10 of 11 (permalink) Old Jul 9th, 10, 05:19 AM Thread Starter
Banned
garay77n84's Avatar
anybody have a pic of the page i need from the aim manual
post #11 of 11 (permalink) Old Jul 9th, 10, 06:19 AM
Look here:
https://www.camaros.net/forums/showth...28#post1447928
It is a link to an '67 AIM uploaded by one of the members here for others to use.
