Gauge Cluster Questions - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 9th, 10, 05:54 AM Thread Starter
Brandon
After I put the gauge cluster back together and installed it, I noticed the gauge lights do not illuminate when the headlights are turned on. The a/c / heater panel works fine. However, the blinker lights stay illuminated when the headlights are on and they work with the dimmer. The blinkers lights flash correctly with the turn signal. No wires were cut, so I think I have the bulbs in the wrong outlet. Any suggestion before I pull it back out?
Thanks!
Brandon
67 Butternut RS 4spd. Muncie w/ OD (0.87 4th)
408CI w/ 508HP/530TQ
, 12 Bolt, Hotchkis Springs, 3" Magnaflow
Wilwood Brakes, March Pulleys, Vintage Air, Foose Legends
brandonvelek is offline
post #2 of 2 (permalink) Old Jul 9th, 10, 09:01 AM
Randy
rs1968ss's Avatar
Re: Gauge Cluster Questions
Check the ground on top of the cluster between the 2 main gauges. Make sure it is nice and clean and making good contact.
-Randy
rs1968ss is offline
