No start - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 8th, 10, 04:27 PM Thread Starter
Dennnis Giles
No start
GM 350 with HEI- NEW BATT, NEW COIL, NEW MODULE,NEWCAP,NEW ROTOR,NEW WIRES, NEW PLUGS with no spark at the plug. Not sure where to start with everything new.Would someone like to suggest a plan of attack?
Deny411 is offline
post #2 of 14 (permalink) Old Aug 8th, 10, 04:31 PM
Re: No start
Coil ground wire hooked up? Goes to one of the coil holddown bolts.
Spring loaded button is installed between the coil and rotor?
BAT terminal mated to HEI?
Rotor touching spring loaded button?
Pick-up coil measures 1000-1500 ohms and hooked up?
Module hooked up?
Swapped old module?
post #3 of 14 (permalink) Old Aug 8th, 10, 05:28 PM Thread Starter
Dennnis Giles
Re: No start
coil ground wire is hooked up.Module is hooked up(only goes one way)Batt terminal is wired to fuse box(IGN).Will have to take the cap back off to double check the rest.So how and where do I check the pick up coil?
Deny411 is offline
post #4 of 14 (permalink) Old Aug 8th, 10, 05:29 PM
Re: No start
Be 100% sure the grounds are good... mainly the one on the motor
68 Camaro~LSx ~all motor
post #5 of 14 (permalink) Old Aug 8th, 10, 05:34 PM Thread Starter
Dennnis Giles
Re: No start
Doug G- I forgot to say replaced the (-) cable with the new Battery You were talking about the Neg battery cable right?
Deny411 is offline
post #6 of 14 (permalink) Old Aug 8th, 10, 05:44 PM
Re: No start
Yes, Doug is talking about the ground cable to the battery and engine block. Also, check to make sure dist body is grounded at the holddown, use an ohmmeter or ohms function of the meter.
Also, to check pick-up coil resistance, unhook the two leads from the module and use the ohms function across the two wires to the coil.
post #7 of 14 (permalink) Old Aug 8th, 10, 05:54 PM
Re: No start
Yes...bit me more than once
post #8 of 14 (permalink) Old Aug 8th, 10, 05:54 PM Thread Starter
Dennnis Giles
Re: No start
OK, back to the garage I go. It is going to be a long night.I have to drive this car to Blacksburg this Sat. Right now I can"t drive it out of the garage.May be a long week!
Deny411 is offline
post #9 of 14 (permalink) Old Aug 8th, 10, 06:29 PM Thread Starter
Dennnis Giles
Re: No start
I took the module loose put ohm meter on 2k scale put leads to the white and green wires that go to the module got a(0.794) reading.? Did I do this right? Checked the continuity between Dist housing and hold down screw (good) and intake manifold also good!
Deny411 is offline
post #10 of 14 (permalink) Old Aug 9th, 10, 03:18 AM
Re: No start
Yes, it is good, but you should unplug the pick-up coil wires, the other side of the module and measure continuity into the disconnected wires, the coil.
The inside connector on the cap, the harness coming from within the dist and hooks to the coil externally, is plugged in good?
The replacement coil, does it have the same color wires as the removed coil, red & white or red & yellow? Both original and new must match colors.
post #11 of 14 (permalink) Old Aug 9th, 10, 05:40 PM
Re: No start
Check to make sure you have 12v at the distributor. I know you said its hooked into the ign on the fuse box, but check for voltage at the distributor.
400bird is offline
post #12 of 14 (permalink) Old Aug 11th, 10, 08:19 PM Thread Starter
Dennnis Giles
Re: No start
I got it started, I replaced the pick-up coil and it fired right up.Thanks for all the help!
Deny411 is offline
post #13 of 14 (permalink) Old Aug 12th, 10, 02:45 AM
Re: No start
Glad to hear
post #14 of 14 (permalink) Old Aug 12th, 10, 03:27 AM
Re: No start
Cool!
