Another CS Alternator question - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 7th, 10, 02:30 PM Thread Starter
Jereme
I have search and not found a direct answer to this question in the forums....
On my CS alternator can I run the "L" wire to switched (ignition) 12VDC source in the engine compartment if I put a 500ohm resister in the line? I have console gauges so no lightbulb in dash.
I just noticed that I have the high pitched whine in the alternator whenever the battery is connected so I appears to be getting constant current. I have the diode in the line to prevent run on; do I still need the resister?
Thanks,
Jereme
1969 L78 SS396 (Engine Long Gone)
BBC 496, TKO600, Beautiful Stock 12 Bolt Posi (maybe the only stock thing left.
RedJet is offline
post #2 of 6 (permalink) Old Sep 14th, 10, 05:59 PM Thread Starter
Jereme
Re: Another CS Alternator question
Bumpity, Bump, Bump... Help Please.
RedJet is offline
post #3 of 6 (permalink) Old Sep 14th, 10, 06:07 PM
ID:	17709 This is all I got.
68 Camaro~LSx ~all motor
post #4 of 6 (permalink) Old Sep 14th, 10, 06:29 PM
Greg
Originally Posted by DOUG G View Post
Attachment 17709 This is all I got.
Doug that is the si alternator wiring diagram isn't it?. Won't help him with the CS130 will it?
RedJet, did you find the lengthy "sticky" in the tech section for CS alternators?
I'll try to find it but it was pretty comprehensive.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
post #5 of 6 (permalink) Old Sep 14th, 10, 06:30 PM
Greg
here ya go...
https://www.camaros.net/techref/ftecref14.html
Greg O is offline
post #6 of 6 (permalink) Old Sep 14th, 10, 06:40 PM Thread Starter
Jereme
Thanks guys. I know that I am probably just a bit of a worry wart, but since I don't have the external regulator (complete rewire of the front end) and don't have idiot lights (gauges). I have neither the bulb or resistance wire. In the interest of simplifying my wiring for the alternator I want to reach out and ask if there is a reason that I would not run the "L" wire to switched (IGN) with a 500ohm resister.
Its my understanding that this wire is only to provide low current 12VDC to the alternator when running to "excite" the alternator. If that is the case then I would think that my plan would work. Just in case I am missing something I wanted to ask...
RedJet is offline
