Ground wire fries - Team Camaro Tech
post #1 of 13 (permalink) Old Nov 11th, 10, 05:22 PM Thread Starter
Marc
Ground wire fries
OK, I have a doozy of a problem. I hooked up a sub woofer and amp in the trunk where the battery is. Ran grounds to the neg and power to the positive sides of the battery. My battery (an Optima) ran dead, so I took it out and charged it. I put it back in, and when I attached the cables, a ground wire (coming from the amp to the deck) started to smoke and fry progressively from the amp. Further, when I tried re-attaching the negative cable, it is arcing like crazy and gets hot. What the hell is going on here?? Nothing changed except I took the battery out of the car- otherwise, no electrical changes. I am stumped. BTW, battery read 12 volts, but quickly ran down to 9.5.
SS69Cam is offline
post #2 of 13 (permalink) Old Nov 11th, 10, 05:34 PM
Steiner
Re: Ground wire fries
The only thing I can think is either a bad amp or the cables were hooked up backwards. This is one reason why you need a fuse right at the postive battery post on your power cable to the amp.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 13 (permalink) Old Nov 11th, 10, 05:38 PM
It reads like the amp is toast, literally.
Also, I believe, the return wire to the head/deck should not be tied to body/chassis ground, but only to the head/deck unit as the return is isolated from the rest of the car. So when the deck is turned on, a power on command goes to the amp to turn it on elctronically. The power-on command circuit should be isolated, maybe. Read amp installation instructions, might show the circuit.
post #4 of 13 (permalink) Old Nov 11th, 10, 05:46 PM Thread Starter
Marc
I think you are both right about the amp, but it truly makes no sense as I didn't change anything other than remove the battery for a charge. The ground wire in question was part of the RCA cables from the amp to the deck. I put one end in the ground spot on the amp, and found out that the other end wasn't even connected yet! Why would it fry like that? The power cable from the amp to the battery does have an in line fuse, but its fine. And why the heck all the sparks and heat from the Neg battery cable?
SS69Cam is offline
post #5 of 13 (permalink) Old Nov 11th, 10, 06:05 PM
Steiner
The ground in the RCA cables is for noise isolation. You might not even need it connected if you don't pick up interference once you get everything up and running.
Try disconnecting everything from the amp and then hook up just your power and ground cable. At this point however, if the amp is toasted it may still have a problem when you connect power to it.
The ground cable immediately getting hot says that there's a current draw when you try to complete the circuit. That shouldn't be so if your turn on lead from the stereo is off.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 13 (permalink) Old Nov 11th, 10, 06:11 PM
The ground wire from the RCA cables is for the noise shield of the cable. Only hook one end of the RCA cable ground. Leave the other end of the RCA cable ground disconnected, otherwise a ground loop is made, bad news.
post #7 of 13 (permalink) Old Nov 11th, 10, 09:51 PM Thread Starter
Marc
Any thoughts of why the negative battery cable is sparking and getting hot? The cables are not reversed. I am totally baffled. And why did the damn ground wire fry????
SS69Cam is offline
post #8 of 13 (permalink) Old Nov 11th, 10, 10:00 PM
Steiner
Do you have a multimeter so you can check from the positive terminal on the amp to the amp case or from the positive terminal to the ground terminal on the amp? Maybe the terminals are mislabeled? What brand and model amp is it?
Ground cable getting hot indicates current draw. That should not happen if the amp is good, amp is off, and cables are correct.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 13 (permalink) Old Nov 12th, 10, 07:34 AM Thread Starter
Marc
I have completely disconnected the amp- which is probably fried anyway. Still neg cable sparking.
SS69Cam is offline
post #10 of 13 (permalink) Old Nov 12th, 10, 08:29 AM
If just the cable is hooked up and no amp on the other end, then its the cable/wire or another circuit in the car.
post #11 of 13 (permalink) Old Nov 12th, 10, 08:50 AM
Michael
Start pulling the fuses out of the fuse box one at a time until you find the faulty circuit.
Then start investigating the devices on that circuit.
mahunt is offline
post #12 of 13 (permalink) Old Nov 12th, 10, 09:23 AM
Mickey
Moonpie's Avatar
Use your meter and take a resistance reading between battery ground and the shell. You may have a less than perfect ground to the body from the battery. Should read under 1 ohm. Check the meter cables to each other first so you know what you're starting with.
Moonpie is offline
post #13 of 13 (permalink) Old Nov 12th, 10, 12:56 PM Thread Starter
Marc
You know what? I am going to go get an AC Delco battery and forget this nonsense.
SS69Cam is offline
