67 Rear Parking Lights Not Working? - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 11th, 10, 05:26 AM Thread Starter
Brandon
After I re-installed the original rear wiring harness, I noticed that the rear parking lights are not working when the headlight switch is activated in either parking or healight position. The brake lights, turn signals, hazards, and back up lights all work properly. Where do I start?
Brandon
67 Butternut RS 4spd. Muncie w/ OD (0.87 4th)
408CI w/ 508HP/530TQ
, 12 Bolt, Hotchkis Springs, 3" Magnaflow
Wilwood Brakes, March Pulleys, Vintage Air, Foose Legends
brandonvelek is offline
post #2 of 5 (permalink) Old Dec 11th, 10, 08:12 AM
Re: 67 Rear Parking Lights Not Working?
Check the brown wire at the body connector in the drvr kick panel for parking light voltage or at the light sockets.
Headlamp switch supplies p/light power for rear as '67 has no front p/lights with headlamps on, but do have front's with parking light position selected.
Make sure the bulbs have nice rounded center contacts to mate with the buttons in the socket. Might need a little cleaning.
post #3 of 5 (permalink) Old Dec 11th, 10, 04:07 PM Thread Starter
Brandon
Good idea regarding the brown wire, thanks. I wonder if it is the switch as my headlight door open, but will not close. I have read that a faulty or dirty switch can cause that problem.
Brandon
post #4 of 5 (permalink) Old Dec 11th, 10, 04:36 PM
Yes, the switch can be a problem.
post #5 of 5 (permalink) Old Dec 12th, 10, 08:54 AM
Brandon, also if the RS door will open but not close it more than likely is a bad ground. I would start there first.
Brandan-
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
