Lower Valance Lights - Team Camaro Tech
post #1 of 13 (permalink) Old Dec 22nd, 10, 06:15 AM Thread Starter
Albert
I am in the last stages of wiring up the car. I would like nothing more than to have the lower valance lights come on as the parking lights w/ the side marker lights.
I believe the valance lights were just for the blinkers, correct??
Has anyone retro-fitted an 1157 bulb to these lights so they will stay on with the parking lights (Low-Beam) and also blink on the high beam side of the bulb?
Seems I can run the parking light wire as well as the blinker wire to this light. Seems the biggest problem would be adding the headlight style connector to these lower valance lights!!
Thanks for any help on this!!
1969 Camaro, 383 stroker, TH400, Moser 12bolt w/ 4.11, Caltracs, GW Suspension.
albud is offline
post #2 of 13 (permalink) Old Dec 22nd, 10, 06:23 AM
Steiner
Re: Lower Valance Lights
'69 lower valence lights come on with parking lights and headlights, and they function as a turn signal. No additional wiring needed.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 13 (permalink) Old Dec 22nd, 10, 06:23 AM
Andrew
Andrew69's Avatar
The valance lights are not just blinkers and they stay on anytime your light switch is pulled. They do that already.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 13 (permalink) Old Dec 22nd, 10, 07:40 AM Thread Starter
Albert
You guys are both on the same page it seems. My issue is that I have seperate wires for the running lights (Brown) and seperate lights for the blinkers (Blue & light blue). They do not tie together. Confused, please clarify for me guys!!
albud is offline
post #5 of 13 (permalink) Old Dec 22nd, 10, 07:44 AM
Guess
HwyStarJoe's Avatar
There are separate pigtails for the parking\turn lights on the harness that runs along the radiator support.
I believe they run through grommets\holes in either the fenders or wheel tubs (can't remember which) and the valance light pigtails will plug into them.
HwyStarJoe is offline
post #6 of 13 (permalink) Old Dec 22nd, 10, 07:48 AM Thread Starter
Albert
Thanks Joe, The car has an aftermarket harness from painless, maybe that's why I'm having issues finding the right way to do this. No pigtails!!
albud is offline
post #7 of 13 (permalink) Old Dec 22nd, 10, 08:15 AM Thread Starter
Albert
ANYONE?? There is only one pigtail for these valance lights. a ground & a power. How can this single pigtail connector function as a running light as well as a blinker?? Please explain!! thank you.
albud is offline
post #8 of 13 (permalink) Old Dec 22nd, 10, 08:27 AM
Andrew
Andrew69's Avatar
I don't believe one wire would power both functions. I am not familiar with Painless wiring (aparantly it isn't) and I suggest you contact them.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 13 (permalink) Old Dec 22nd, 10, 08:57 AM
Robert
There are only 2 wires and the ground comes from the body. One of the wires you suspect to be the ground is likely the running light. The wiring diagram I'm looking at says it's a brown wire.
Robert
TC member #18
rojo is offline
post #10 of 13 (permalink) Old Dec 22nd, 10, 08:59 AM
There should be two wires going to each valance light. Neither is a ground. The driver's side should have a brown (prk light) and a light blue (turn). The pass side should have a brown (park) and a dark blue (turn). The socket uses a chassis ground.
dual fillament/dual nubbon bulb (1157?)
BPOS is offline
post #11 of 13 (permalink) Old Dec 22nd, 10, 09:15 AM Thread Starter
Albert
Robert & Al, You guys may have hit this right on the head!! I do have the brown wire as the running lights and a blue wire for the turn signal. I will check to see if both wires hooked up to the valance light works properly.
Thank you guys very much for the schooling!!!
Merry Christmas....
albud is offline
post #12 of 13 (permalink) Old Dec 22nd, 10, 03:29 PM
prostreet69camaro's Avatar
The painless wiring harness has a light blue and dark blue wire which is your blinker wires. The brown is the running lights. One filement is brighter than the other on the bulbs. Make sure they are connected to the correct color wires.
prostreet69camaro is offline
post #13 of 13 (permalink) Old Dec 25th, 10, 10:41 PM
Fred
Albert you're in good hands. Let us know how it's going and merry Christmas. I can dive into and under the lights with the camera if you need more info. Hell, even my bulbs are original. Yep, 1157's.
128.79mph 1.428 60'
Fred Ficarra is offline
