68 Camaro front blinker lights ? - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 26th, 10, 12:23 PM Thread Starter
Jeff
68 camaro when I press the brake the front blinker lights come on, bubs are correct?
penzaj is offline
post #2 of 7 (permalink) Old Dec 26th, 10, 01:33 PM
Re: 68 camaro front blinker lights ?
I seen this before on "older" cars...........I think it's a bad ground ?
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Dec 26th, 10, 03:35 PM
As Doug suggests, a bad ground at the radiator support where the ground wire is attached frot he sockets or an additional ground, hosed clamped to the socket, and grounded on the rad support.
Unless a new steering wheel harness is used, or dash harness, and it would be wired wrong, kind of unlikely but probable.
post #4 of 7 (permalink) Old Dec 28th, 10, 09:37 AM Thread Starter
Jeff
thanks I will check the grounds but I did look at them quickly and they seem to be grounded at the fire wall.
penzaj is offline
post #5 of 7 (permalink) Old Dec 28th, 10, 10:35 AM
I added grounds to mine from the light to the core support.
post #6 of 7 (permalink) Old Dec 28th, 10, 12:39 PM Thread Starter
Jeff
they are grounded at the radiator support do you think I need addtional ground?
penzaj is offline
post #7 of 7 (permalink) Old Dec 28th, 10, 12:56 PM
Double check that they're grounded and no rust or paint under the wires
