temp/oil/gen/brake lights - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 5th, 11, 09:51 PM Thread Starter
Wayne
Having trouble getting my camaro's GEN, BRAKE, and OIL lights coming on. . . Do I have to have the floor console gauges plugged up first? The BRIGHT light comes on when I hit the foot dimmer switch.
Thanks.
'69 Z28 // 02D // 9n603xxx
Custom 308ci high-windin' mouse!
1969.02dx33 is offline
post #2 of 6 (permalink) Old Jan 5th, 11, 10:16 PM
Re: temp/oil/gen/brake lights
On the same circuit, does your fuel gauge and temp light work? Temp light should also glow in the start position before cranking.
Check the fuse marked "gauges" and that it's connection is good..
10A fuse, lowest, right.
BlackoutSteve is offline
post #3 of 6 (permalink) Old Jan 5th, 11, 10:43 PM Thread Starter
Wayne
No, the blue bright light is the only light that comes on. I also don't have my floor console plugged up, so that may have something to do with while they're not coming on?
I know my oil sending unit is getting grounded through the block, to the battery, then to the car body. And, too, the e-brake switch on the e-brake has been cleaned and it reads continuity, also.
post #4 of 6 (permalink) Old Jan 6th, 11, 03:36 PM
Sometimes it's as simple as burned out bulbs.
BPOS is offline
post #5 of 6 (permalink) Old Jan 6th, 11, 04:00 PM Thread Starter
Wayne
Checked 'em, lol.
post #6 of 6 (permalink) Old Jan 6th, 11, 04:13 PM
Best advice though.. Simple things first.
