Converting to a newer 1 wire alternator - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 15th, 11, 09:18 AM Thread Starter
Edm
Ed
I tried to find a 100A "CS" alternator referenced in tech tip #14 but couldn't find any with the 6 and 12 o'clock mounting positions to fit my existing March pulleys. I ended up buying a Power Master one wire alternator with an internal regulator. A little direction with the wiring would be much appreciated. How can I safely wire this and remove the external regulator without messing anything up?
Edm is offline
post #2 of 12 (permalink) Old Jan 15th, 11, 11:47 AM
Vega$69's Avatar
Re: Converting to a newer 1 wire alternator
Just run the Red ALT wire. Abandon the reg wires at the Alt and the Reg.
Vega$69 is offline
post #3 of 12 (permalink) Old Jan 15th, 11, 06:26 PM Thread Starter
Edm
Ed
What does that Red alt. wire connect too? I need to put a larger gauge wire in and would like to keep everything as neat and clean as possible.
Edm is offline
post #4 of 12 (permalink) Old Jan 15th, 11, 08:18 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
The battery.
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
post #5 of 12 (permalink) Old Jan 15th, 11, 11:59 PM
Larry
larryh56's Avatar
A 1-wire will not allow any method of remote voltage sensing so it can not compensate for and drop in voltage from lights, electric fans, a/c, etc. Check out MadElectrical.com for some good info on how to wire up a internal regulated newer alternator and the problems with the 1-wire. This is a good post: https://www.camaros.net/forums/showth...ernator+wiring
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #6 of 12 (permalink) Old Jan 16th, 11, 06:13 AM Thread Starter
Edm
Ed
Originally Posted by Orange68SS View Post
The battery.
I UNDERSTAND THAT. It goes to the existing voltage regulator or the horn relay first THEN TO THE BATTERY.
Edm is offline
post #7 of 12 (permalink) Old Jan 16th, 11, 06:23 AM Thread Starter
Edm
Ed
Great info. Thanks.
The alternator I ordered was supposed to be 3 wire. I am just gonna send it back. This is frustrating.
Anyone know of a 105 A "CS" alternator with a 12 and 6 mounting position?
Edm is offline
post #8 of 12 (permalink) Old Jan 16th, 11, 07:14 AM
This says late-80's GM truck or full size car... http://www.novaresource.org/alternator.htm
markw is offline
post #9 of 12 (permalink) Old Jan 16th, 11, 02:36 PM
Chris
67RSSS's Avatar
H-body cars like the Olds 88, Bonneville, etc.
67 RSSS Van Nuys, 4th week Sept,1966
ps,tilt,headrest,spd warn,pw,am/fm,delux int,
remote mirror,rear defrost,tint glass.etc...
TKO 600 Extreme,12bolt 3:73 gears.
67RSSS is offline
post #10 of 12 (permalink) Old Jan 18th, 11, 12:23 PM Thread Starter
Edm
Ed
88 Delta 88 has the 12 and 6 mounting pattern. Every truck alternator found from 86 on had the 3 holes and wouldn't work for my application.
Edm is offline
post #11 of 12 (permalink) Old Jan 18th, 11, 02:57 PM
My CS130 was designed for some mid-90s area chevy truck. I remember the part number was something odd like 123456A or somesuch (almost looked fake). The point however is that I reclocked the alternator to fit properly. I just removed the 3 or 4 case screws, turned the halves to align the way I needed and reinstalled the screws.
dnult is offline
post #12 of 12 (permalink) Old Jan 18th, 11, 06:56 PM Thread Starter
Edm
Ed
Thats a good idea too but this Delta 88 is a perfect fit.
Did you wire yours the way the tech tip says too? I noticed on the Novasource site the schematic was slightly different. I want to get it right the first time if possible. Did you wire a fusible link in to the alternator or at the horn relay?
Thanks,
Ed
Edm is offline
