powerless - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 15th, 11, 08:33 PM Thread Starter
jerry
JERRYS 69 Z's Avatar
powerless
have brand new battery up to full power. drove car into shop to work on
this winter. everythingworked fine. pulled fancy radio with lots of heavy
wiring and got rid of it. since then, absolutely no power at all. don,t
remember if i disconnected battery or not at the time. is there a main
fuse that may have blown? any suggs. i'm not good at electrical stuff.
thanks.
JERRYS 69 Z is offline
post #2 of 4 (permalink) Old Jan 15th, 11, 08:45 PM
Jeremie
Re: powerless
Make sure your ground from battery is good. Then just work your way back words. From memory: positive battery cable runs to starter. Check that for power at starter. Then purple and yellow? Maybe run to bulkhead on engine compartment side. Use a test loght to check that for power. Keep testing wires as you work your way forward. You can put a test light on each fuse inside the car to check that. I wpuld also try a new battery as well.
MTN10 is offline
post #3 of 4 (permalink) Old Jan 15th, 11, 10:43 PM
Re: powerless
- Charge battery
- Clean battery posts and both ends of battery cables
- Check the wire that goes from the + batt cable around to the front of the radiator support. there is a junction there - clean that
- check and clean the busbar on the horn realy
BPOS is offline
post #4 of 4 (permalink) Old Jan 15th, 11, 11:33 PM
Larry
larryh56's Avatar
Re: powerless
Check all the connections on the horn relay. There is a fusible link that you should check that powers the dash. Pull on the wire, if it stretches it is burned out and needs to be replaced.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
