The electrical gremlins never end - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 18th, 11, 04:01 PM Thread Starter
Marc
So now when I turn on the headlights, the driver side light come on. When I hit the highbeam switch, driver goes off and passenger side lights up. Oh come on! Seriously???
SS69Cam is offline
post #2 of 8 (permalink) Old Jan 18th, 11, 05:32 PM
Bruno
Re: The electrical gremlins never end
1st make sure the headlamps are in good condition. I've seen that before.
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #3 of 8 (permalink) Old Jan 18th, 11, 06:33 PM
X2.
Is alternator charging too high at battery posts?
NMT 14.5 volts at 2500 rpm at operating temperature.
post #4 of 8 (permalink) Old Jan 19th, 11, 09:04 AM
Sean
Typical old car stuff. About 45% of the time it's a ground issue, another 45% is a rusty or bad connection. The other 10%...... good luck, lol.
Sometimes its obvious like bad bulbs etc as pointed out above. Your best bet is check grounds and get a voltmeter and start checking sockets and plugs. I chased grounds and rusty sockets in my car for weeks.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 8 (permalink) Old Jan 19th, 11, 09:35 AM Thread Starter
Marc
Geez, grounds are so underrated. Will check this out. Thanks all.
SS69Cam is offline
post #6 of 8 (permalink) Old Jan 19th, 11, 09:46 AM
Bad connections form a chain too. Seems like when you find and fix one, the next weekest link reveals itself. Don't be surprised if you have to chase a few. Even the fuse terminals themselves can give you fits.
dnult is offline
post #7 of 8 (permalink) Old Jan 19th, 11, 11:54 AM
Sean
So true about one leading to another.
Good point about the fuse box, my prongs on the fuse box where rusty and I chased a wiper motor switch issue for awhile until I noticed the rust there. If the windshield leaks it leaks right on the box.
The good news is once you get it sorted out it shouldn't give you trouble, mine was bad when i got the car but has been really good for awhile now. ...of course I just jinxed myself....ha.
Sean
68rs406 is offline
post #8 of 8 (permalink) Old Jan 20th, 11, 08:52 AM
Fred
77thor's Avatar
Problems like these are why I am slowly replacing all wire harnesses in my car...
77thor is offline
