What is this? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 22nd, 11, 03:51 PM Thread Starter
Joseph
What is this?
Wondering what this is on the firewall on drivers side. Thanks
cam1967rsss is offline
post #2 of 7 (permalink) Old Jan 22nd, 11, 03:56 PM
Re: What is this?
Hard to say, but it looks to have been added. Could be a anti-theft device as in a switch to cut power to the dash harness or part of an alarm system. Look on the opposite side of the firewall up under the dash.
BPOS is offline
post #3 of 7 (permalink) Old Jan 22nd, 11, 05:01 PM
Camarodude67
Re: What is this?
Yes was added, maybe a positive jumper terminal? I guess take a voltage for each post.... As Al stated, Security Alarm, Power Winows, Power Top or a fancy radio?
Jeff G.
69 Verts
camarodude67 is offline
post #4 of 7 (permalink) Old Jan 22nd, 11, 05:10 PM
Jon
Re: What is this?
Same thing I use in my trucks to activate my snow plow pumps. Can you follow them back? Basically it just sends power to another source. One large wire should come right off bat?
JR67RS is offline
post #5 of 7 (permalink) Old Jan 23rd, 11, 12:52 AM
Re: What is this?
Looks like a Ford Starter solenoid
Musclerodz is offline
post #6 of 7 (permalink) Old Jan 23rd, 11, 09:08 AM
DjD
DjD's Avatar
Re: What is this?
I was thinking the same thing but then I thought about when I had a travel trailer I pulled around and my truck had something like that for isolating the trailer battery when the ignition was off to prevent running the trailer off the truck battery...
...Dennis
DjD is offline
post #7 of 7 (permalink) Old Jan 29th, 11, 07:55 PM
Re: What is this?
Yes, it's a Ford starter solenoid.
It was a common mod to wire one into the starter circuit to correct the hot cranking problems that many GM vehicles had.
Like any relay, it can be used for just about anything as the others have already said. You'll have to follow the wires to find out for sure why it's there on your car.
67 Camaro, 96 LT1, 4L60E
red67camaro is offline
