Push button start. what amprage? - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 31st, 11, 11:20 AM Thread Starter
Noel
I wanting to install a P.B. start but im not sure the amout of current will be pressent. does anyone know?
1967 SBC
HoeyNoey is offline
post #2 of 10 (permalink) Old Jan 31st, 11, 12:11 PM
Kevin
KevinW's Avatar
Re: Push button start. what amprage?
You do not want that to go through a small button switch, better off installing a relay and let the power go through that. http://www.the12volt.com/relays/relays.asp
Kevin
KevinW is offline
post #3 of 10 (permalink) Old Jan 31st, 11, 12:27 PM
Robert
I used a generic starter switch from Advance on an engine test stand and it worked great. It didn't get daily use but I think it would have held up.
http://shop.advanceautoparts.com/web...7CGRP60036____
Robert
TC member #18
rojo is offline
post #4 of 10 (permalink) Old Jan 31st, 11, 12:41 PM
Vic
http://www.shopfesler.com/products/T...op-Switch.html
Comes with relaypak too.... plus adds a little better look
Vic
1969 Camaro SS
Camaro1969 is offline
post #5 of 10 (permalink) Old Jan 31st, 11, 02:47 PM
Is this a remote start or just a push button??
john68 is offline
post #6 of 10 (permalink) Old Jan 31st, 11, 05:03 PM
68
They actually make a system similar to what Mercedes uses.. You carry a transmitter/card in your wallet and when you get within a few feet it activates the switch and energizes the push to start button...
A buddy installed it on his bike...
Yellow camaro is offline
post #7 of 10 (permalink) Old Jan 31st, 11, 07:16 PM
Steiner
A 15-20A rated button will be plenty if you're wiring it into the purple ignition wire. Otherwise, you can get some much snazzier buttons and use a relay with the purple wire on the relay contacts like others suggested.
I've got one of these in a box somewhere that I was going to use as an interlock on my start circuit. I've just got a jumper where the old neutral safety switch used to plug in and was going to put it there.
http://www.summitracing.com/parts/PCO-5512PT/
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 10 (permalink) Old Jan 31st, 11, 11:42 PM
Nev
I saw this keyless kit that looked intersting
http://www.ididitinc.com/accessory_p...o_keyless.html
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #9 of 10 (permalink) Old Feb 1st, 11, 09:42 AM Thread Starter
Noel
wow thanks fellas!
HoeyNoey is offline
post #10 of 10 (permalink) Old Feb 1st, 11, 09:57 AM
The one from Summit as Steiner suggested works fine.
I had two of them wired in my previous car, one in a bracket on the intake for bumping the engine over during valve adjustment, and one installed in the radio knob hole in case the ign switch ever failed to 'start'.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
