69 Turn Signal Switch Replacement - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 7th, 11, 07:22 PM Thread Starter
George
How to remove steering shaft lock plate clip once steering wheel has been removed
GBT69 is offline
post #2 of 9 (permalink) Old Feb 7th, 11, 07:37 PM
Re: 69 Turn Signal Switch Replacement
You have to press down on the lock plate and hold it, then use a scribe to remove the retaining ring. Then lock plate comes right off.
I bought a Harbour Freight tool for $2 - had a coupon.
Well, this one does both, remove the s/wheel and lock plate:
http://www.harborfreight.com/steerin...set-42031.html
post #3 of 9 (permalink) Old Feb 7th, 11, 08:02 PM Thread Starter
George
Thank for the information, I will have to try to make some type of press off the steering shaft. could not press down with hand enough to remove clip. but will try harder.
GBT69 is offline
post #4 of 9 (permalink) Old Feb 7th, 11, 08:25 PM
Steiner
AutoZone or Advance most likely has a kit like Everett linked that they'll rent to you. Just pay for it up front and they refund all of your money when you return it.
Getting it out with a small screwdriver isn't very hard without pressing it down but getting it back on is tough. I had my wheel off and on a half dozen times in one day when troubleshooting the horn circuit and my fingers were shot after that.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 9 (permalink) Old Feb 7th, 11, 09:41 PM
Steps
Save on special tool...find a use for the wife or one of the children
you push down real hard and have them flick it out with a screwdriver....
Its alsop quicker than ordering the tool or going up the road to rent.
If it hasnt been off in a few decades..it may need a thump with a small mallet and bit of wood just to intially free it up if u cant press it down.
Similar thread to one a few weeks back asking the same thing.
Steptoe is offline
post #6 of 9 (permalink) Old Feb 8th, 11, 08:21 AM
Jeff
yellow69RS's Avatar
I own the tool and wouldn't do it any other way. I've done a few Caddilacs with tilt/telescopic wheels and the tool doesn't work on those, major pain if you ask me.
Jeff
yellow69RS is offline
post #7 of 9 (permalink) Old Feb 8th, 11, 08:40 AM
Jeff,
On the T&T column you have to install a #12 allen screw into the threaded end of the upper shaft to prevent it from telescoping. Then the tool works just fine.
Here is a picture of the tilt column locking plate and the retaining ring. If you deform the ring (similar to the picture) you are going to have to purchase a new one. The GM part number for the ring is 5694191. I would think that it is probably available at most automotive supply stores as well (probably cheaper than the dealer price.)
JIML82 is offline
post #8 of 9 (permalink) Old Feb 8th, 11, 10:21 AM Thread Starter
George
Have not been able to get back to the job of switch replacement, but with all of the good information I sure I,ll get something done even if it,s tearing it up. then I just buy one of the new tilt columns. but would like to stay original. THANKS AGAIN
GBT69 is offline
post #9 of 9 (permalink) Old Feb 9th, 11, 07:51 AM
Jeff
yellow69RS's Avatar
Originally Posted by JIML82 View Post
Jeff,
Why didn't someone tell me that 30 years ago..... When I was making a living at this?
Jeff
