amp gauge - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 9th, 11, 09:12 AM Thread Starter
amp gauge
hi guys im converting my 69 camaro to have console gauges and i am confused as to how to wire the amp gauge. anyone have any input?
1967 Camaro RS
383 Stroker 427HP 457TQ
Tremec TKO-600
Strange Engineering 12-Bolt 4.11 Posi
Coys C-55 18" Wheels
Scott MH is offline
post #2 of 8 (permalink) Old Feb 9th, 11, 09:40 AM
Jeremie
Re: amp gauge
Im guessing that you bought a conversion harness from aaw? If that is the case then its kinda a plug and play type deal. This is what I did on the engine compartment side.
black wire connects to positive battery junction block located behind the battery. Black/white wire to positve screw on horn relay. Both should have orange fusible links attached. Thats where it goes once it leaves engine side fuse block. Im assuming ur wires are already wired to dashside fuse block?
MTN10 is offline
post #3 of 8 (permalink) Old Feb 9th, 11, 10:37 AM Thread Starter
Re: amp gauge
no i didnt buy the harness just making my own. but thanks for the input itll help the process
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #4 of 8 (permalink) Old Feb 9th, 11, 06:44 PM
Jeremie
Re: amp gauge
If you did'nt buy the harness then the colors of the wires wont matter. Just make sure it is hooked up to the junction block and horn relay. Then the wires will run into the back of the amp gauge.
MTN10 is offline
post #5 of 8 (permalink) Old Feb 9th, 11, 07:31 PM
Sean
Re: amp gauge
And add the fusible links! It'd be shame for all you work to go up in smoke.
68 Convertible | stockish 350 | 700r4 | 3rd Gen Power Steering | Dual Electric Fans | MSD Ignition | Island Teal
GR8_68 is offline
post #6 of 8 (permalink) Old Feb 11th, 11, 12:24 PM Thread Starter
Re: amp gauge
ok so both wires for the amp gauge to the horn relay would work? (for some reason my car doesnt have a junction box behind the battery). what size fuseable link should i use? i think the standard is two wires under the wire your are protecting
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #7 of 8 (permalink) Old Feb 11th, 11, 02:48 PM
Re: amp gauge
Hook one wire to the postive battery clamp and add 4-6 inches of fusible length, say 20 AWG. If meter defects in the wrong direction, reverse leads on back of meter. The standard for fusible link is 4 AWG less than the wire being protected.
post #8 of 8 (permalink) Old Feb 11th, 11, 02:54 PM
Milt
Milt's 68 SS/RS 396's Avatar
Re: amp gauge
You can get the junction post from all of the restoration part suppliers. Around 7 dollars
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
