Dash Indicator Light Bulbs - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 12th, 11, 03:07 PM Thread Starter
Help! I have some bulbs burnt out (turn signal indicator, etc). So I removed the speedo & tach covers and the bulbs are starring right at me but I can't remove. They sit within this little square box that no human being has fingers small enough to grap and pull. I bought new bulbs #194 to see how they are affixed and it looks like they slide in and out. Is there a special tool? I'm afraid needle nose pliers will break the glass.
Frustrated 69 Camaro Rally Sport
jabeyers is offline
post #2 of 9 (permalink) Old Feb 12th, 11, 04:17 PM
Re: Dash Indicator Light Bulbs
If you have very skinny arms and hands, a 1/4 turn they come out from the back, And the double jointed wrist.
john68 is offline
post #3 of 9 (permalink) Old Feb 12th, 11, 04:25 PM
I have my dash ripped apart so I went out and checked. Those are buggers, but a needle nose did the trick. Just squeeze the pliers a little beyond what feels comfortable and they pull right out. If it does break the bulb, no biggie, and then you'll have something substantial to grab. Those are spade type bulbs on a 69 and are push-in pull-out type, no 1/4 turn.
BPOS is offline
post #4 of 9 (permalink) Old Feb 12th, 11, 04:55 PM
Kind of correct, the bulbs pull out of the socket, the socket is the 1/4 turn, use some tape on the needle nose, or a small piece of vacuum tubing???
john68 is offline
post #5 of 9 (permalink) Old Feb 13th, 11, 07:39 AM Thread Starter
They are not the 1/4 turn socket type. I will rig the needle nose with some tape or whatever and give it a yank.
Thanks,
jabeyers is offline
post #6 of 9 (permalink) Old Feb 13th, 11, 07:44 AM
Jeff
yellow69RS's Avatar
There is a way to get the indicator light assembly out from behind the dash carrier and then the bulbs stick past the holdder. I don't think the effort is worth it. I think I'd try to push some vacuum hose or rubber tubing over the buld and pull it out instead.
Jeff
yellow69RS is offline
post #7 of 9 (permalink) Old Feb 13th, 11, 08:07 AM Thread Starter
Jeff,
I actually pulled that out but the bulb location didn't change at all.
jabeyers is offline
post #8 of 9 (permalink) Old Feb 13th, 11, 09:29 AM Thread Starter
FYI.....The needle nose with tape on the ends worked like a charm. Bad news is that 3 of the idiot lights that were not working (gen, temp & oil) didn't have bulbs because the socket terminal clips have been broken. Looks like I'll be on the hunt to replace that rack. Any ideas on where I might locate one.
Not so frustrated 69 Camaro Rally Sport,
jabeyers is offline
post #9 of 9 (permalink) Old Feb 13th, 11, 09:39 AM
Daryl
1968RallySport's Avatar
Napa Auto Parts
1968RallySport is offline
