Which wire? - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 17th, 11, 04:52 PM Thread Starter
Cory
Which wire?
my 2nd post and I already need some help, lol, anyway, which wire powers up the fuse/junction box? Here is what I am wanting to do.
Im converting over to 1 wire alt. I'm going to run a 6al and a ford starter solonoid and run a power wire to the junction box. I'm just going to use the fuse box for my lights.
Is it the 1 wire that joins the battery terminal from horn relay
Is it the 1 wire that comes from inside the car to the horn relay
68 with a 505cid
Temple is offline
post #2 of 4 (permalink) Old Feb 17th, 11, 06:04 PM
Re: Which wire?
The wires you speak of are joined together at the horn relay, so are essentially the "same" wire.
BPOS is offline
post #3 of 4 (permalink) Old Feb 18th, 11, 05:43 AM
Guess
HwyStarJoe's Avatar
Re: Which wire?
See if this will help... .PDF format files: http://www.gvtc.com/~rlaa/
HwyStarJoe is offline
post #4 of 4 (permalink) Old Feb 18th, 11, 06:24 PM Thread Starter
Cory
Re: Which wire?
BPOS, yea your right its basically the same wire. Its the smaller gauge that goes to the battery.Im just goignt to run a 30 amp in-line fuse and take it to the solonoid. thanks
68 with a 505cid
Temple is offline
