Is the 1969 headlight washer solenoid rebuildable? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 18th, 11, 07:28 AM Thread Starter
Timothy
I broke off one of the electrical connections when I was wrenching on my car. It was probably already stressed from being improperly packed when shipping but I finished it off. Also it did not work at all when connected.
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #2 of 7 (permalink) Old Feb 18th, 11, 07:44 AM
Jeff
yellow69RS's Avatar
Re: Is the 1969 wiper washer solenoid rebuildable?
Replacement parts should be available from aftermarket and maybe dealer. The down side is the aftermarket plastic parts are black not white like OEM. It might be possible to buy replacement pump and just use the electrical from it with the metal and plastic from the original. If you take the 4 screws holding nozzles on out you can push in and rotate the plunger 1/4 turn to remove it if necessary.
Jeff
yellow69RS is offline
post #3 of 7 (permalink) Old Feb 18th, 11, 11:00 AM
Kevin
KevinW's Avatar
Tim, you talking about the headlight washer soleniod or the windsheild washer pump? Never heard the term 'wiper washer soleniod'
Kevin
KevinW is offline
post #4 of 7 (permalink) Old Feb 18th, 11, 11:56 AM Thread Starter
Timothy
Re: Is the 1969 headlight washer solenoid rebuildable?
Sorry, its the headlight washer solenoid on the wiper motor.
post #5 of 7 (permalink) Old Feb 18th, 11, 01:00 PM
Kevin
KevinW's Avatar
Not rebuildable, the coil wires and spade connectors are molded into the plastic case. I have extra repro ones, PM me if interested.
Kevin
KevinW is offline
post #6 of 7 (permalink) Old Feb 18th, 11, 07:38 PM
Jeff
yellow69RS's Avatar
Funny that the edit of the subject isn't on the first two replies. I was assuming the washer pump when I posted my reply.
Jeff
post #7 of 7 (permalink) Old Feb 19th, 11, 09:37 AM
click's Avatar
edit function goes away after a few hours. darn new software but it has its place too.
click is offline
