Instrument bezel and light socket question - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 19th, 11, 03:55 PM Thread Starter
I am installing the insturment cluster in my 69 and have a couple questions.
Heres a little backgroud info: The insturment cluster (bezel, gauges, etc) are new repos. I added the tach and clock option also. The wiring is new also. It is an American Auto Wire, factory fit harness.
Thr dash harness is installed, I am about to install the insturment cluster and am plugging all the connectors to the back of the cluster.
My first question is: do you install the dash pad before the cluster or after the cluster is in place?
Second: is a little complicated, I am trying to figure out which of the light sockets on the AAW harness get plugged into the top of the Tach housing area and the top of the Speedometer housing area. There is also a clock which needs a light socket to it. I looked the AAW harness over and there are light sockets but I see two that fit the clock housing and one that fits the tach or speedometer housings. I need two for the tach and speedometer housings and one for the clock. I am trying to figure out if I am doing something wrong or the harness is wrong.
If anyone can post a picture of an original tach/clock insturment cluster and harness it would be a great help. Thanks
justsomeguy is offline
post #2 of 3 (permalink) Old Feb 19th, 11, 04:10 PM
Jeremie
Re: insturment bezel and light socket question
I put dash pad on last. In regards to the lights, there should be 3. Each gauge, or clock has a hole on the top that will fit only one light. It really doesnt matter which bulb goes where as they all turn on at the same time. I dont have any pics but I did my conversion a few months ago
MTN10 is offline
post #3 of 3 (permalink) Old Feb 20th, 11, 05:22 PM Thread Starter
Re: Instrument bezel and light socket question
Thanks. I installed it today and after a bit of tweaking, got everything hooked up. I had the dash pad on already so I took it back off and did the cluster. Did not get the dash pad back on, do that in the morning.
Thanks again
