wiper switch - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 28th, 11, 03:51 PM Thread Starter
wiper switch
can anyone tell me what the wires are supposed to do on a 69 camaro wiper switch? i have a wiring diagram but i cant tell which one is supposed to activate the washer pump. my wipers function in two speeds but the pump does not engage. im getting 12 volts to the two post that is supposed to activate the silnoid that engages the pump arm....if that makes sense.
1967 Camaro RS
383 Stroker 427HP 457TQ
Tremec TKO-600
Strange Engineering 12-Bolt 4.11 Posi
Coys C-55 18" Wheels
Scott MH is offline
post #2 of 9 (permalink) Old Feb 28th, 11, 03:55 PM
Fred
Re: wiper switch
Scott, are you referring to two posts on the switch or on the pump solenoid?
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 9 (permalink) Old Feb 28th, 11, 05:51 PM
Re: wiper switch
Dark Blue - washer pump
Black - wiper low speed
Lt. Blue - wiper high speed (or just not quite as slow as "slow speed")
The wiper switch is on the "ground" side of the circuit
BPOS is offline
post #4 of 9 (permalink) Old Feb 28th, 11, 06:54 PM
Brent
67Rally's Avatar
Re: wiper switch
Yeah, mine only has slow and medium. No high speed.
67Rally is offline
post #5 of 9 (permalink) Old Feb 28th, 11, 09:37 PM Thread Starter
Re: wiper switch
Yes one the pump itself sorry it wasn't clear
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #6 of 9 (permalink) Old Mar 1st, 11, 03:49 AM
Brent
67Rally's Avatar
Re: wiper switch
Dark blue is ground and completes the circuit when the washer switch is activated. Yellow is hot when ignition is in acc position.
67Rally is offline
post #7 of 9 (permalink) Old Mar 1st, 11, 06:39 AM Thread Starter
Re: wiper switch
Ok so I am getting power to the electromagnet and when the button is pushed the ground is created I tried jumping direct bat power and it still won't engage so I assume it's fried what makes me mad is that it's a brand new washer mechanism
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #8 of 9 (permalink) Old Mar 1st, 11, 10:27 AM
Brent
67Rally's Avatar
Re: wiper switch
Have you checked your grounds on the wiper motor?
67Rally is offline
post #9 of 9 (permalink) Old Mar 1st, 11, 10:50 AM Thread Starter
Re: wiper switch
It was a bad ground! Thanks for the help guys
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
