Fuse box Ignition terminal vs. resistive wire - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 13th, 11, 07:45 PM Thread Starter
dan
sixd8rs's Avatar
Can the male fuse box terminal marked "ignition" be used instead of the old resistive wire. Box needs 12v when ignition is turned on. Being used to power a MSD Digital 6 box.
68 RS
sixd8rs is offline
post #2 of 3 (permalink) Old Mar 14th, 11, 05:17 AM
Re: Fuse box Ignition terminal vs. resistive wire
Yes, that terminal should only have power when the key is in the on position.
U.S Air Force Retired
68 RS/SS, 396 BBC .060 over, M-20, 373 12 Bolt, factory color Island Teal blue, redline bias ply tires.
knuggles68RS/SS is offline
post #3 of 3 (permalink) Old Mar 14th, 11, 08:01 PM
Steiner
X2. Actually has power in "Run" and "Start" which is what you need. Be sure and disconnect the old yellow wire coming from the aux contacts on the starter.
'69 Camaro
500hp/538lbft
Steiner is offline
